LeahMorgan Posted November 5, 2022 Share Posted November 5, 2022 I've searched through the forum and cannot seem to locate this inquiry elsewhere. I am working on an island, and would like to recess the toekick on the side of a cabinet with a 3" setback to match the cabinet turned on the side. Any tips on how to best accomplish this? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 5, 2022 Share Posted November 5, 2022 27 minutes ago, LeahMorgan said: Any tips on how to best accomplish this? Hi , you haven't done your Forum signature so I don't know what version you have but in X14 if you turn off Flat sides it should give you what you need. Link to comment Share on other sites More sharing options...
LeahMorgan Posted November 5, 2022 Author Share Posted November 5, 2022 Thank you for both tips! Link to comment Share on other sites More sharing options...
LeahMorgan Posted November 5, 2022 Author Share Posted November 5, 2022 @Kbird1 Solved one but created another lol... on the end cabinet I have a closed toe. But it wants to retain the closed toe on the left side of the cabinet. Can this be toggled to function separately (left / right)? Link to comment Share on other sites More sharing options...
robdyck Posted November 6, 2022 Share Posted November 6, 2022 I believe you'll need to uncheck 'Closed Toe' and add a gable end to the right of the MW cabinet. You could also use an end panel on the cabinet but a gable end will be much quicker to place and to control. Use the 'Partition' tool to place a gable end. Link to comment Share on other sites More sharing options...
MarkMc Posted November 6, 2022 Share Posted November 6, 2022 19 hours ago, LeahMorgan said: Can this be toggled to function separately (left / right)? You can turn it off by setting the side separation to "0", you can then add the side separation back using the front configuration panel. The cabinet must be listed as Framed- if it is meant to be frameless just set : box construction, framed, separation to 3/4" If normal framed then use 1-1/2 On front panel set that side to have 0 separtion. Now on front panel select vertical layout and split vertical Select the new vertical separation and "move left" Select the new Layout Vertical and delete Done 1 Link to comment Share on other sites More sharing options...
LeahMorgan Posted November 7, 2022 Author Share Posted November 7, 2022 Thank you everyone!!!! Link to comment Share on other sites More sharing options...
