WALL ELEVATIONS
winterdd
2 hours ago, ChiefUserBigRob said:
One thing I have never figured out is how to get the NKBA dims to measure to the center of openings or the rough openings and not the casing. I have checked and unchecked so many boxes in the settings and still nothing? Advice?
Hi Rob,
The NKBA dims are a fixed standard for the "National Kitchen & Bath Association".  None of the settings will change those standards.  As DBC suggested, you will need to use the "Elevation Dims" instead if you want anything different.
21 minutes ago, joey_martin said:
Are you using those for a cabinet maker? When I provide interior elevations I use standard dimensioning a builder would use.
No, most builders have their own cabinet guys who take my drawings and do their thing. I still provide them though and just provide as much info as I can.
