winterdd Posted September 15, 2022 Share Posted September 15, 2022 How do you guys achieve this on window settings? Thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 15, 2022 Share Posted September 15, 2022 Niche? Niche with applied Shutters? -or- Window with Shutters closed? 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 16, 2022 Author Share Posted September 16, 2022 do we have this option in X13? "show shutters closed"? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 16, 2022 Share Posted September 16, 2022 48 minutes ago, ChiefUserBigRob said: do we have this option in X13? "show shutters closed"? No, it's an X14 feature. 2 Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2022 Share Posted September 16, 2022 Another way to inset the shutters: Place one of the shutters from the library, copy and butt it up against the first one. Group select them and convert them to a symbol, during which you get the option to Show Advanvced Options>Options>Special Placement>Inserts Into Wall>Depth. It dosn't show the cutout in plan though - but easily fixed. Not that you would want to, but you can then change the shape and size of the cutout. This way may not have enough options or flexibility to suit you particular case, I am just throwing it out there on the off-chance it may be useful. 1 Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2022 Share Posted September 16, 2022 Another quick way to make a wall recess is with a Wall Material Region. 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 16, 2022 Author Share Posted September 16, 2022 Thanks guys for the feedback. I knew it was a matter of time before this window type was requested from a client. Link to comment Share on other sites More sharing options...
DBCooper Posted September 16, 2022 Share Posted September 16, 2022 You could always just say no. Link to comment Share on other sites More sharing options...
winterdd Posted September 16, 2022 Author Share Posted September 16, 2022 58 minutes ago, DBCooper said: You could always just say no. Negative, not for what I charge to do plans. They get what they want. 1 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 16, 2022 Share Posted September 16, 2022 3 hours ago, ChiefUserBigRob said: Negative, not for what I charge to do plans. They get what they want. Assuming that you are charging them that much then why not just upgrade to X14? 2 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 17, 2022 Author Share Posted September 17, 2022 4 hours ago, Joe_Carrick said: Assuming that you are charging them that much then why not just upgrade to X14? Because all hell broke loose when I upgraded from X12-X13 from my library and other files. I finally got X13 set up just like I want. I will upgrade in the future though and read more on migrating settings. Link to comment Share on other sites More sharing options...
