mprovost129 Posted August 31, 2022 Share Posted August 31, 2022 Ever since I upgraded to X14 I've had an issue where the trim doesn't populate on some of my roofs / roof belts. Has anyone else had this issue? Maybe I should try reinstalling X14? These roofs were copied from the adjacent roof that has the trim and has the same properties. It just makes no sense. I sent a request to support, and they couldn't recreate it at the time. 220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip Link to comment Share on other sites More sharing options...
MoeGia Posted August 31, 2022 Share Posted August 31, 2022 Don't bother reinstalling. Have you forced a roof rebuild? Are the roof planes joined together properly? If there's a slight misalignment, you'll see odd behavior. I didn't look at your file but is the camera cut too close to the bay? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 I downloaded your "file" and it would not open in X14 because you attached it while the plan file was actively open in Chief= Zero Kb=no good, try again but close Chief FIRST before attaching the plan file here a CT. DJP Link to comment Share on other sites More sharing options...
mprovost129 Posted August 31, 2022 Author Share Posted August 31, 2022 4 minutes ago, DavidJPotter said: I downloaded your "file" and it would not open in X14 because you attached it while the plan file was actively open in Chief= Zero Kb=no good, try again but close Chief FIRST before attaching the plan file here a CT. DJP Thanks, I've re-uploaded the file. 220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip Link to comment Share on other sites More sharing options...
mprovost129 Posted August 31, 2022 Author Share Posted August 31, 2022 15 minutes ago, MoeGia said: Don't bother reinstalling. Have you forced a roof rebuild? Are the roof planes joined together properly? If there's a slight misalignment, you'll see odd behavior. I didn't look at your file but is the camera cut too close to the bay? Yes I've tried rebuilding. I've checked all the alignments. It's happened for months. Originally I thought it was a glitch with the software. If nobody else has this issue though, then it's got to be the install or my settings. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 On inspection I SEE NO missing trim, it looks great to me but obviously, there is something missing for you. Can you be a little more specific, please? DJP Link to comment Share on other sites More sharing options...
mprovost129 Posted August 31, 2022 Author Share Posted August 31, 2022 Just now, DavidJPotter said: On inspection I SEE NO missing trim, it looks great to me but obviously, there is something missing for you. Can you be a little more specific, please? DJP DJP I've drawn in the trim using polylines. Remove the polyline trim and see if it's there. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 I deleted all of your molding polylines and used a combination of "Auto Roof Full Return" along with manual roofs over just the bay... DJP 220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 When you draw manual returns, how they are aligned and connected directly determines whether or not you get fascia, any version. You DID get it done, actually. But with Chief, any version, there is usually more than one way to get an effect. DJP Link to comment Share on other sites More sharing options...
mprovost129 Posted August 31, 2022 Author Share Posted August 31, 2022 27 minutes ago, DavidJPotter said: I deleted all of your molding polylines and used a combination of "Auto Roof Full Return" along with manual roofs over just the bay... DJP 220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip 10.12 MB · 0 downloads Can you show me the settings you used? I tried to recreate it, but can't seem to get it right. I didn't have these issues before X14. There must be some settings withing the walls/roofs that were updated. Maybe something added in? Link to comment Share on other sites More sharing options...
mprovost129 Posted August 31, 2022 Author Share Posted August 31, 2022 20 minutes ago, solver said: Please check your messages -- envelope icon top of page. Auto build roofs are quick and easy. Thanks. The person that I learned from didn't like using the auto roofs, so I never took the time to learn them. I will look into it. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 31, 2022 Share Posted August 31, 2022 9 minutes ago, mprovost129 said: Thanks. The person that I learned from didn't like using the auto roofs, so I never took the time to learn them. I will look into it. It is always well worth starting with Auto Roofs , they will get you there 65-95% of the way , with all the correct overhangs, baseline heights etc, but with todays' Home designs , there are always conditions Chief can't handle Auto , so there is inevitably some cleanup to do afterwards. M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 3 hours ago, mprovost129 said: Can you show me the settings you used? I tried to recreate it, but can't seem to get it right. Initially, I simply checked "Roof Tab - Auto Roof Return - Full" on the long wall and then manually added the roof returns on the bay window walls. Doing it that was lessons the chances of bad manual roof connections. Doing it all manual as you have seen, often makes simple tasks too complicated. I agree with Eric in that Auto Roofs for this house would have been easier to do. To learn more about auto Roof settings go to the Build Roof dialog - Roof Styles Tab for more data. I almost always start a roof system automatically and then just manually edit what it got wrong. The product is the thing, not how it was created. DJP Link to comment Share on other sites More sharing options...
mprovost129 Posted September 1, 2022 Author Share Posted September 1, 2022 22 hours ago, DavidJPotter said: Initially, I simply checked "Roof Tab - Auto Roof Return - Full" on the long wall and then manually added the roof returns on the bay window walls. Doing it that was lessons the chances of bad manual roof connections. Doing it all manual as you have seen, often makes simple tasks too complicated. I agree with Eric in that Auto Roofs for this house would have been easier to do. To learn more about auto Roof settings go to the Build Roof dialog - Roof Styles Tab for more data. I almost always start a roof system automatically and then just manually edit what it got wrong. The product is the thing, not how it was created. DJP Thanks DJP. I appreciate the help. I've been using Chief for a couple of years. I know enough to get by, but still have lots to learn and tinker with. Link to comment Share on other sites More sharing options...
