Door Schedules
BruceKC
Go to solution Solved by robdyck,
Does anyone know why my door schedules have odd descriptions, such as Hinged-Door P02, or Garage-Door p12?  Talked to support and although they were great as always, they weren't sure why the default macros are giving me those strange descriptions.  One garage door shows "Garage-Door P12), the other says "Garage-Design 2 - Rec 14.  Totally puzzled.
6 minutes ago, BruceKC said:
here is the schedule
Hey Bruce, you gotta help us to help you! Simply make a copy of the plan file, and strip it down, then zip it up. Or use a dropbox or google drive link.
The plan file is pretty important to seeing what's going on...in the plan file!
The Description Name normally comes from the Symbol name via the %Automatic description% macro AFAIK ( search the Library for the same name) but supplying the Stripped down Plan is going to be you best move here..
2 minutes ago, BruceKC said:
From what I can tell looking those things up in the library, they are specific door styles from the Chief Library.  Hmmm.  Thanks everyone.
As an experiment add the following 2 columns to your schedule: Type and Style. Together those form most of the automatic description. And your right, the description takes the name of the Library symbol.
Robert,
I used the "ex/in" and type and that will work for me.  Style still delineates the "style of the door from the library", which I don't see how that would be relevant unless it were a custom homeowner's project.  You've been a great help, thanks again!
Robert,
Look a little closer to his description of what to use:
2 hours ago, robdyck said:
Depending on what info you want included, you could use these 2 columns to drop the library symbol name.
