Brick wall poking through sheetrock
Jonathan3891
Not much "wrong" with your wall connections or custom layers of those walls. I can't find anything particularly "wrong" with what you did other than the unwanted brick reveal. That can be handled cosmetically using a Wall material region or a custom backsplash set to drywall. Chief is quite good but never has been nor will probably ever be "perfect", sometimes you have to step in and work-round things to get a product no matter what.
14 hours ago, Jonathan3891 said:
What am I doing wrong?
You are not laying things out accurately enough. If you zoom tightly in on these corners, you'll notice the interior wall doesn't align with the inside of the exterior wall. That will need to be fixed on both floor levels.
image.thumb.png.da95ca808a3f3155f1117991b31465a8.pngimage.thumb.png.c719884dc5f11591c2bd24a19719a136.png
After the correction:
