Jonathan3891 Posted August 24, 2022 Share Posted August 24, 2022 I cant figure out how to fix the brick wall poking through the sheet rock as shown below. What am I doing wrong? Boeke House.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 25, 2022 Share Posted August 25, 2022 Not much "wrong" with your wall connections or custom layers of those walls. I can't find anything particularly "wrong" with what you did other than the unwanted brick reveal. That can be handled cosmetically using a Wall material region or a custom backsplash set to drywall. Chief is quite good but never has been nor will probably ever be "perfect", sometimes you have to step in and work-round things to get a product no matter what. DJP Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 25, 2022 Share Posted August 25, 2022 i think you can get rid of it by changing the wall intersections, but not sure if that causes other issues Link to comment Share on other sites More sharing options...
robdyck Posted August 25, 2022 Share Posted August 25, 2022 14 hours ago, Jonathan3891 said: What am I doing wrong? You are not laying things out accurately enough. If you zoom tightly in on these corners, you'll notice the interior wall doesn't align with the inside of the exterior wall. That will need to be fixed on both floor levels. After the correction: Link to comment Share on other sites More sharing options...
robdyck Posted August 25, 2022 Share Posted August 25, 2022 No offense, but how neatly would you expect the model to display when it's laid out like this? The whole building is completely random. I would expect random results. 1 Link to comment Share on other sites More sharing options...
