VikingFan84 Posted January 23, 2015 Share Posted January 23, 2015 Hello, I am inexperienced with using the elevation and terrain feature. I want to have a flat elevation about 6" below my baseboard in the lower level and then I want a different leveled elevation a couple inches below the garage door and other front facing walls. The multiple elevations can be separated by a retaining wall. I've tried to draw elevation lines but have found they result in a slope which I don't believe I'm looking for, or if so I'm not sure exactly how to make it. I've attached 3 photos which show that my base terrain is at the level I want for the lower level. I believe it's set to 81" elevation pad. I now want to create different regions with raised elevations and retaining walls between but am not sure how to accomplish this. Any insight would be appreciated, thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 23, 2015 Share Posted January 23, 2015 I recommend using elevation regions for each of the differing levels but there must be a small gradient change between differing levels,I mean you must expect some transition space from level to level. You draw the region and then open its dialog and set its height for the space it controls , using just elevation regions alone you can get done what you need and want.Try it and see for yourself (it won't bite, much) DJP Link to comment Share on other sites More sharing options...
Gawdzira Posted January 23, 2015 Share Posted January 23, 2015 If you only need the elevations and not the full 3d model views, just make a cad polyline with a solid fill in the elevation camera view that you are sending to layout. Link to comment Share on other sites More sharing options...
VikingFan84 Posted January 23, 2015 Author Share Posted January 23, 2015 I recommend using elevation regions for each of the differing levels but there must be a small gradient change between differing levels,I mean you must expect some transition space from level to level. You draw the region and then open its dialog and set its height for the space it controls , using just elevation regions alone you can get done what you need and want.Try it and see for yourself (it won't bite, much) DJP Thanks I think this is the method I'm looking for although I haven't found too much success yet. Attached is how I've layed out my regions. The 2nd picture shows one of my problems. Raising the red section (garage) for some reason affects the complete opposite end of the house (Yellow). I've searched for a fairly simplistic elevation guide but most tutorials and the like deal with seemingly more complex issues than I think I need. As always any insight would be greatly appreciated. Link to comment Share on other sites More sharing options...
glennw Posted January 24, 2015 Share Posted January 24, 2015 It's quite easy to get vertical changes of level. You can use either the Terrain Break or a Terrain Retaining Wall. Draw either and then place a small Elevation Line at the top and bottom of the retaining wall or Terrain Break with the appropriate elevation. Retaining Wall on the left, Terrain Break on the right. Link to comment Share on other sites More sharing options...
VikingFan84 Posted January 26, 2015 Author Share Posted January 26, 2015 It's quite easy to get vertical changes of level. You can use either the Terrain Break or a Terrain Retaining Wall. Draw either and then place a small Elevation Line at the top and bottom of the retaining wall or Terrain Break with the appropriate elevation. Retaining Wall on the left, Terrain Break on the right. This is what I'm looking for. So I have a terrain perimeter set to an elevation of 81" (which is actually low just below the basement siding). I draw a terrain break vertically (does it need to go through both ends of the perimeter or could I just draw one 10' long for example?). Then I draw two elevation lines (crossing the line, parallel with the line, on top of the line?) and set them to the elevation I want. I haven't worked much with elevations and seemingly missed the tutorial video. Thank you for the responses. Link to comment Share on other sites More sharing options...
glennw Posted January 26, 2015 Share Posted January 26, 2015 You draw the elevation lines parallel to the Terrain Break/Retaining Wall. Link to comment Share on other sites More sharing options...
