X14 doesn't work with teamviewer, but X13 does...
armfx89
Go to solution Solved by armfx89,
There is a different connection between the client window and the content displayed in Teamviewer.  This can lead to the program being displayed but not what the program is running.  Try displaying the whole screen and not just sharing the CA window.  If that works, then there is a problem with Teamviewer itself.  By the way, a similar thing happens with the program OBS for streaming or recording tutorials, and the work around there is to display the whole screen with tweeks to resolution and cutting what is displayed.  I am not an expert with this but if Rene reads this, I bet he could explain it much better than I.
  • 2 months later...
  • Solution
Just an update on this. I have found the cause of this issue after all these months. It has to do with power saving mode. I used to tilt the screen of my home laptop down...this puts it in some power saving mode causing the X14 issue when remotely accessed via teamviewer. I have stopped tilting the screen and now it works fine!!!!
