ACADuser Posted August 5, 2022 Share Posted August 5, 2022 I have a plan attached that when I draw a leader Rich text the leader has an override line weight of 30. Can anyone tell me where the 30 line weight setting is coming from? Untitled 1.zip Link to comment Share on other sites More sharing options...
evergreen Posted August 5, 2022 Share Posted August 5, 2022 Select arrow and check line weight in Active Layer Display Options at the bottom Link to comment Share on other sites More sharing options...
ACADuser Posted August 5, 2022 Author Share Posted August 5, 2022 I Know How To Fix It, I want to know why it was created at an override line weight of 30? Link to comment Share on other sites More sharing options...
evergreen Posted August 5, 2022 Share Posted August 5, 2022 If you open the arrow and under line weight, its look like at one point it was changed to 30. The arrow below connected to Rich Text "REPLACE DOOR" is checked "By Layer" at a line weight of 2. Outside of this, not sure what the source of the problem is especially if it's something that keeps happening. Link to comment Share on other sites More sharing options...
ACADuser Posted August 5, 2022 Author Share Posted August 5, 2022 Thanks for looking at this. This plan file creates leaders at 30 with the line weight default unchecked. I have opened the leaders & checked default to get them to default line weight. Leaders I create come in at 30 with default unchecked. I can't figure out why. If you create a new leader is the default line weight checked? Link to comment Share on other sites More sharing options...
evergreen Posted August 5, 2022 Share Posted August 5, 2022 Yes, I can reproduce this...Opening a new plan, though, this does not happen. Not sure... Let's see if someone else will chime in with some more insight. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 5, 2022 Share Posted August 5, 2022 That linestyle is being inherited from your Rich Text Defaults>Appearance>Border Link to comment Share on other sites More sharing options...
ACADuser Posted August 5, 2022 Author Share Posted August 5, 2022 Thanks Michael, great detective work. I see the border set at 30 which is what I want for borders. But why is the leader using that number? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 5, 2022 Share Posted August 5, 2022 6 minutes ago, ACADuser said: Thanks Michael, great detective work. I see the border set at 30 which is what I want for borders. But why is the leader using that number? It's because the Leader Line tool always obeys the settings for the text object that it is created for. In the case of Rich Text though, the Border settings are the only place to set line style parameters. Link to comment Share on other sites More sharing options...
robdyck Posted August 6, 2022 Share Posted August 6, 2022 FWIW, this only happens when a leader line is used to create the rich text. If an arrow is dragged from the rich text after the text is created, the arrow takes the layer line weight. Link to comment Share on other sites More sharing options...
ACADuser Posted August 6, 2022 Author Share Posted August 6, 2022 That;s a nice little nugget. Thanks Link to comment Share on other sites More sharing options...
John_Charles Posted Monday at 09:50 PM Share Posted Monday at 09:50 PM I'm having an issue with this also however I'm just trying to thicken it up. I have tried changing the appearance but seem to only get a line weight of 1 which shows up very light for a curve unless I zoom in.... any thoughts? Link to comment Share on other sites More sharing options...
