JDTyler Posted January 20, 2015 Share Posted January 20, 2015 Going to try this again, didn't get an actual answer earlier. I want to start selling stock plans online and all the sites I've viewed have plans that look like the attached picture. They're very simplified and have solid walls so they're easy to understand for customers who don't know how to read plans. I haven't found a way to accomplish this same look in CA. Is there another program that creates these simpler plans? Apart from creating a custom layer set (which still doesn't look like the picture) I haven't figured out how others are doing it. Anybody out there know how they're getting that result? Link to comment Share on other sites More sharing options...
Solution mattyt12 Posted January 20, 2015 Solution Share Posted January 20, 2015 Copy your wall types so you can change back for Construction Docs but edit the wall type and change the fill types to black. Kitchen Cabinets fill style can be edited in the dbx. Fixtures may need a new CAD block created with a grey fill, only needs to be done once then can be saved in the Library Shortland - Marketing Material 11-02-14.pdf Link to comment Share on other sites More sharing options...
JDTyler Posted January 20, 2015 Author Share Posted January 20, 2015 MattyT12 that's what I was afraid of lol! That's going to take fooreeevvveeer. I'm going try and figure out something with layer sets, save it as a template and then I can do that instantly with every plan from then on. Probably won't work but we'll see. Thanks for also including the cabinet/fixture work around, hadn't got to that point yet. Anyone else have another way? Link to comment Share on other sites More sharing options...
mattyt12 Posted January 20, 2015 Share Posted January 20, 2015 Set your different wall types to different layers so you can isolate and group select all the same wall type and change in one go. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 20, 2015 Share Posted January 20, 2015 Basically, what Matty said.Guadalupe floor plan marketing.pdf Link to comment Share on other sites More sharing options...
Doggies1954 Posted January 20, 2015 Share Posted January 20, 2015 That's going to take fooreeevvveeer. Sorry but that's just not true. It should only take you a few minutes to do what Matty said. Link to comment Share on other sites More sharing options...
joey_martin Posted January 20, 2015 Share Posted January 20, 2015 It is accomplished with layer sets. These are for a project I sell online. Took about 2 mins to create a layer set called "Marketing" and send it to a 8.5"x11" layout page. You are over thinking it. I use this dark gray fill in my construction documents, so there is no need to mess with that at all. Link to comment Share on other sites More sharing options...
joey_martin Posted January 20, 2015 Share Posted January 20, 2015 Here is what the fill looks like in construction documents. Link to comment Share on other sites More sharing options...
ArthurDent Posted January 20, 2015 Share Posted January 20, 2015 You can also do this using the wall hatch tool. I think it is easier then changing the wall type because then you can control everything with layers. Just place wall hatches on all walls. You can marquee select them all while in hatch tool mode. Change the fill style to solid and what ever color you want. Then turn off the layer for "walls, layers.". If you want to make your life easier, just set up a new layer set with the wall hatching on and wall layers off to switch between presentation floor plan and construction drawings. Link to comment Share on other sites More sharing options...
