Footeconst3 Posted June 30, 2022 Share Posted June 30, 2022 (edited) Is there a quick / simple way to draw a hoop style building in CA? I am designing the interior for an out of state customer and they want a second floor so it would be helpful if I could draw the building in order to do 3D interiors. I will be drawing the building to assist with the foundation, end wall, lighting infrastructure and a future addition. Any suggestions are appreciated before I take the long way around the block. Thank you! Edited June 30, 2022 by Footeconst3 Link to comment Share on other sites More sharing options...
CharlesVolz Posted June 30, 2022 Share Posted June 30, 2022 "Curved Roof Planes" in help. Link to comment Share on other sites More sharing options...
rgardner Posted June 30, 2022 Share Posted June 30, 2022 6 minutes ago, CharlesVolz said: "Curved Roof Planes" in help. Hint: You will probably need 5 roof planes connected together to accomplish this look. Link to comment Share on other sites More sharing options...
MarkMc Posted June 30, 2022 Share Posted June 30, 2022 What others said, though did this with 4 planes, 5 would be better....this should get you started- right side shows the start. Likely need to adjust wall and roof structure defaults first. Adjust overhang until correct, adjust corner board, not much can be done with default wall at top (add solid to cover) Link to comment Share on other sites More sharing options...
Footeconst3 Posted January 1, 2025 Author Share Posted January 1, 2025 THANKS! Link to comment Share on other sites More sharing options...
