tomm11 Posted June 27, 2022 Share Posted June 27, 2022 Sounds silly for an architectural program but I'm doing wood carving + want to draw a pattern Link to comment Share on other sites More sharing options...
Gawdzira Posted June 27, 2022 Share Posted June 27, 2022 .plan files are 1"-1". When you go to print you need to adjust your scale. You can send to layout and print at 1-1. If you are printing directly from the .plan file, I would suggest changing your methodology. Link to comment Share on other sites More sharing options...
rgardner Posted June 27, 2022 Share Posted June 27, 2022 7 minutes ago, tomm11 said: Sounds silly for an architectural program but I'm doing wood carving + want to draw a pattern Do you have a question? The default is already at 1:1 you scale it when you put it into layout, or if you draw it in something else manually. By default you are already there. Link to comment Share on other sites More sharing options...
tomm11 Posted June 28, 2022 Author Share Posted June 28, 2022 oh yea. when I import a 9 inch pdf + the the image scales to 34 ft all I have to do is divided by 45.33. The idea pdf changing the dimension scale was throwing me off. thanks Link to comment Share on other sites More sharing options...
rgardner Posted June 28, 2022 Share Posted June 28, 2022 1 hour ago, tomm11 said: oh yea. when I import a 9 inch pdf + the the image scales to 34 ft all I have to do is divided by 45.33. The idea pdf changing the dimension scale was throwing me off. thanks Select the pdf and use the resize tool on a known dimension. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted June 28, 2022 Share Posted June 28, 2022 3 hours ago, tomm11 said: oh yea. when I import a 9 inch pdf + the the image scales to 34 ft all I have to do is divided by 45.33. The idea pdf changing the dimension scale was throwing me off. thanks If there really is not much editing involved you might want to consider skipping the plan file all together and import directly to layout. Link to comment Share on other sites More sharing options...
