Lock or Shift the Fill Pattern to Polyline
buzzsaw204
Go to solution Solved by DG1949,
hi,
When you hatch to polyline with a grid pattern, and you move the polyline, But the fill pattern stays stationary.
is there an option to lock or shift the hatch Fill pattern to the Polyline?
So that the grid pattern stays in line with a Polyline, the way you intended to be.
  • Solution
You can select the polyline and the grid fill and create a block. However, if you "un-block, the fill pattern will revert.
Alternatively, you can move the fill pattern with the "Offset and Angle" values, but that won't lock to the polyline.
on this related subject,
when you use the Siding..ei. Hardie Panel... on your Wall, and it provide its Fill/Hatching.
is there a way to shift & move that Fill/Hatching  to the get alignment you want,  or you're pretty much stuck with the pattern it gives you??
How walls display in camera views (and this includes elevation views) is controlled by materials.  Vector views, will use patterns and the other rendering techniques will use textures.  So if you are trying to control the pattern of a wall material, take a look at the settings on the Pattern panel of the Define Material dialog for the material the wall is using.
This support article has some information that might help:
https://www.chiefarchitect.com/support/article/KB-00194/changing-the-direction-of-a-material-s-pattern-and-texture.html
More information about materials can also be found in our training videos:
https://www.chiefarchitect.com/videos/playlists/170/materials-patterns-textures.html
