HarrisReno Posted June 2, 2022 Share Posted June 2, 2022 I don't even know if the changes I want to make to my roof are logical, so criticism is welcomed and, I know, will come freely. I have several walls within this plan that I want to have a gable roof, but auto-roof does not create the right "size" gable. Or, it creates holes and chaos with the roof. I'm attaching the plan and pictures with notes that explain my problems better. Thank you in advance for your help. Wendy Plan01-NoInterior.plan Link to comment Share on other sites More sharing options...
rgardner Posted June 2, 2022 Share Posted June 2, 2022 Looks like a redesign of the footprint to get anything close to what you are trying to accomplish. Link to comment Share on other sites More sharing options...
HarrisReno Posted June 2, 2022 Author Share Posted June 2, 2022 Thank you, Eric, so much for the video. Very helpful and insightful, as always. I tried with all my might to semi-replicate your design, but I'm failing. I'm sure the attached plan will make you want to bang your head against a brick wall, but I really think I'm close (and I did add some windows, doors, and interior walls). Here's what's not working and what I would like to work (very sorry for bombarding with so many questions!)... 1. Changing the pitch of the roofs that run perpendicular to the garage to 7" did not get me close to the ridge of the garage. Why does a 7" pitch work on your plan, but I have to lower it to nearly 5-1/2" or less on my plan to get the roofs to meet at the the same height? 2. Obviously, the rear of the house is in terrible shape. I want to keep the "double gable" look like you have on the two walls to the right of the rear perspective. However, I'd like another gable centered over the exterior wall of the Great Room. Ideally, I'd like to have windows that match the roof line, and make it a "grander" view in general. As you can see, when I make that portion a gable, it "marries up" to the two right gables, losing the look completely. - I do hope to have some kind of vaulted ceiling in the great room. Ideally, something that matches the roof line of the gable I want to add. But, is this even possible, given the gable roof that's running the opposite direction? I'm just not sure what my ceiling plane options will be in here. I would hate for it to be a flat ceiling, and a tray ceiling would still prevent me from having those tall windows. 3. I don't know how to do the shed roof that you have in your plan. My shed roofs have always been manually drawn. I tried selecting the wall and choosing "High Shed/Gable" but that was clearly not the right move. 4. I'm mentioning the obvious, but, as we can see in the roof "holes," there are walls extending into the attic that I don't think should be there. Will this be fixed when the roofs are fixed, or do I need to do something about the rogue walls? 5. I'm probably mentioning this far too late, but is this supposed to be two-stories (or, at the least, one and a half) if I want to add dormers? Yikes! Thank you to all for your feedback and help! Plan01-RoofAndInterior.plan Link to comment Share on other sites More sharing options...
Gawdzira Posted June 2, 2022 Share Posted June 2, 2022 Link to comment Share on other sites More sharing options...
HarrisReno Posted June 2, 2022 Author Share Posted June 2, 2022 1, 2, 3 - Yes! The taller gable between the garage and gable 1 is not necessary. Link to comment Share on other sites More sharing options...
HarrisReno Posted June 2, 2022 Author Share Posted June 2, 2022 I can't get the two rear gables to separate, let alone make a third gable. I'm sure my expectations are outside the logic of architecture. I'm just going with the attached plan and calling it good!! Thank you so much for all your help! I couldn't have gotten this far without all the input!! Plan01-RoofAndInterior.plan Link to comment Share on other sites More sharing options...
SNestor Posted February 15, 2024 Share Posted February 15, 2024 @HarrisReno - I think what you were originally attempting is possible (somewhat) but definitely not with the auto roof tool. Here's my attempt... 2 Link to comment Share on other sites More sharing options...
