ionkin_DESIGN Posted May 24, 2022 Share Posted May 24, 2022 Which setting is responsible for these half circles? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 24, 2022 Share Posted May 24, 2022 Ouch... Did those arrive with the Auto Detailing ? Link to comment Share on other sites More sharing options...
ionkin_DESIGN Posted May 24, 2022 Author Share Posted May 24, 2022 Yes, sir. Wasn't expecting this and the worst part is i can't select them to manually remove them.. Link to comment Share on other sites More sharing options...
rgardner Posted May 24, 2022 Share Posted May 24, 2022 Well that's a new one. Why don't you load up the plan file so we can take a look. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 24, 2022 Share Posted May 24, 2022 Do they go away when you delete the associated wall detailing ? If not you may need to post the plan or contact tech support. Link to comment Share on other sites More sharing options...
Gawdzira Posted May 24, 2022 Share Posted May 24, 2022 Try removing the insulation and then redoing the section (wild guessing). Link to comment Share on other sites More sharing options...
ionkin_DESIGN Posted May 24, 2022 Author Share Posted May 24, 2022 Thanks for suggestions! I checked my wall defaults and sure enough the wall type i was using had another layer of framing on the interior layer also check marked for auto insulation. Problem solved. Link to comment Share on other sites More sharing options...
