SHCanada2 Posted May 22, 2022 Share Posted May 22, 2022 I have a property line which is not parallel to the house, and for some reason I cannot snap to the line, it keeps wanting to snap to the where the off angle line meets the vertical line. I read the manual and thought it was the "Exensions" but I turned that off and it still does not work. any ideas. in the attached video it starts off snapping to the line but then moves off of it. any ideas? I can place a CAD marker to get around it, but I think I am missing something simple 21.05.2022_17.29.28_REC.mp4 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 22, 2022 Share Posted May 22, 2022 It doesn't sound like you're missing anything. Dimensions snap to a number of specific points on various model objects but those points are almost if not always either at corners, start/end nodes, break points, or at object centers. What you're trying to do doesn't coincide with any of those. You're trying to snap to a random intersection point along a line. There's nothing for Chief to associate this random location with (which becomes a really issue when moving/resizing the referenced object). You have a few options: Use Point To Point Dimensions which will automatically drop a point marker at your desired location so that Chief has something to associate the dimension with Place the dimension perpendicular to the referenced line so that Chief can just use the end node Place a break in your referenced line so that Chief has something to associate the dimension with Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2022 Share Posted May 22, 2022 with "unruly" Dims like those I find the Perpendicular (PP) Tool is handy to make the Dim PP to the Line, in the Video you have drawn it straight up the page hence not PP to the line this will make it look like the Dim snapped back to where you clicked. ( Ext. Line is on PL line now, so not noticeable, but Marker/attachment is likely still out on Corner Node) M. * re-worded to please Michael Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 22, 2022 Share Posted May 22, 2022 16 minutes ago, Kbird1 said: with "unruly" Dims like those I find the Perpendicular Tool is handy to stop the Dim snapping to the nearest Node ( corner) it should then snap back to where you clicked. M. I already mentioned placing the dimension perpendicular. Its not really snapping to the point where you clicked though like you're claiming. It's just that Chief isn't drawing the extension because it's unnecessary. Its easy to prove too. Just dimension to a line and then change the angle of that line. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2022 Share Posted May 22, 2022 5 minutes ago, Alaskan_Son said: I already mentioned placing the dimension perpendicular. And your point is? 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 22, 2022 Share Posted May 22, 2022 Just now, Kbird1 said: And your point is? My point is that you've just repeated what I already said. I also thought the extra information you added to your post was unnecessary and a little misleading. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2022 Author Share Posted May 22, 2022 2 hours ago, Alaskan_Son said: Use Point To Point Dimensions which will automatically drop a point marker at your desired location so that Chief has something to associate the dimension with I am using P2P, its not dropping a marker. I did use P2P and dropped a marker far enough from the line and then moved the marker. but thats not what I want because I am moving the property line to get the correct setback. 2 hours ago, Alaskan_Son said: Place a break in your referenced line so that Chief has something to associate the dimension with this worked well and kept the polyline rectangular intact. thanks 2 hours ago, Alaskan_Son said: Place the dimension perpendicular to the referenced line so that Chief can just use the end node works well too if I did it correctly, ironically I already had an end dimension there, I just never tried to snap to the corner (intersection of the blue PL and dim end) both the above two allow me to move the polyline rectangle and see the setback dim change as I move to get what I want thanks. the 3'6 is snapping to the corner of the vertical dim end line and the blue PL (I just moved it to the left) 1 hour ago, Kbird1 said: Perpendicular Tool I dont understand, is this the same as putting in a dimension perpendicular, or is this doing something with the perpendicular tool Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 22, 2022 Share Posted May 22, 2022 3 hours ago, jasonn1234 said: I am missing something simple I think the simplest way is to draw a line between the two points you want to dimension. Then the dimension tool will easily snap to the end points of that line. The advantage of this approach is that you can see and adjust that line to make sure it’s where you want it, before dimensioning. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2022 Share Posted May 22, 2022 13 hours ago, Michael_Gia said: I think the simplest way is to draw a line between the two points you want to dimension. Then the dimension tool will easily snap to the end points of that line. The advantage of this approach is that you can see and adjust that line to make sure it’s where you want it, before dimensioning. I also use this trick at times, but you don't need to Dimension the Line , just turn on the Arrow both ends and "Show Length" in the Line's DBX. M. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2022 Share Posted May 22, 2022 14 hours ago, jasonn1234 said: is this the same as putting in a dimension perpendicular, or is this doing something with the perpendicular tool You aren't putting the Dim in perpendicular to the line but to the House/Page in the Video, which is fine as that's how CA will some snap best sometimes.... but you then need to set the Dim. Line PP to the PL/SB line, which will make it look like the Dim snapped back to where you clicked. ( the Ext. Line is on PL line now, so not noticeable, but Marker/attachment is likely still out on the Corner/Break Node, unless using a PT-PT Dim) M. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2022 Share Posted May 22, 2022 15 hours ago, Alaskan_Son said: My point is that you've just repeated what I already said. I also thought the extra information you added to your post was unnecessary and a little misleading. I don't see the problem as mentioned , it happens and is done by all the time around here reinforcing Other's Ideas and comments.... M. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 24, 2022 Share Posted May 24, 2022 On 5/22/2022 at 9:56 AM, Kbird1 said: I don't see the problem as mentioned , it happens and is done by all the time around here reinforcing Other's Ideas and comments.... M. You're right, it does happen all the time. If you're really just trying to reinforce something that's already been said though, I think it goes a long if you qualify your statement as such with something like: As so and so already stated... I agree with so and so... To add to what so and so stated... Etc. Or if you don't want to give credit to a specific person and instead just want to build on the idea: To expand upon what was already pointed out... I agree that... I too think that... I second... In order to achieve the aforementioned... Etc. Not only is it courteous, but referencing the original statement also helps tremendously if your goal is to bolster and truly reinforce a common idea/discussion instead of creating what might seem like a whole new one. It just helps keep things a lot more easy to follow when there's a common reference point. There's my 2 cents. 1 1 Link to comment Share on other sites More sharing options...
