KellySantaRosa Posted May 2, 2022 Share Posted May 2, 2022 Hello, I am having trouble getting the full elevation view to show up in my "CAD detail from view" function. This used to be done easily and essentially the same image from the elevation would show up in a cad detail window. See screen shots of the very minimal image that I am now getting when i perform this function. Any ideas? Thanks, Kelly Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 2, 2022 Share Posted May 2, 2022 Make sure all the appropriate layers are turned on in that CAD Detail’s layer set. It looks to me like all your layers are turned off except for your cross-section lines layer. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 2, 2022 Author Share Posted May 2, 2022 Yeah, everything is on. I turned every layer on and still same as the screen shot I sent Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 2, 2022 Author Share Posted May 2, 2022 So, new, but most likely related issue: here is a sequence of me using the elevation camera, turning on back clip to 30", and then showing the elevation camera again. No walls, no foundation, no roof planes, next to nothing shows up. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 2, 2022 Share Posted May 2, 2022 maybe post the plan, assuming you tried the "all layers on" layer set Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 3, 2022 Author Share Posted May 3, 2022 I did try "all on set" Here is a link to the plan file: https://www.dropbox.com/s/jjp1fuiw9h7xi1o/Janny and Urs.plan?dl=0 Thank you for your help Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 3, 2022 Share Posted May 3, 2022 2 hours ago, KellySantaRosa said: I did try "all on set" Here is a link to the plan file: https://www.dropbox.com/s/jjp1fuiw9h7xi1o/Janny and Urs.plan?dl=0 Thank you for your help I think your problem is being caused by the fact your model is about 2 miles from the origin. I would suggest you used Edit Area (All Floors) to move everything back to 0,0. I think that should fix your problem. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 3, 2022 Author Share Posted May 3, 2022 That didn't work. My assistant started this file and I think she did something screwy. She quit so I can't ask her. It seems to me like there is a setting that is turned to the wrong function. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 3, 2022 Share Posted May 3, 2022 1 hour ago, KellySantaRosa said: That didn't work. My assistant started this file and I think she did something screwy. She quit so I can't ask her. It seems to me like there is a setting that is turned to the wrong function. Try it again. It should work. You may want to open the cameras one by one and and reposition them by clicking Fill Window Building Only, but I tested it out and once the building is back at 0,0, everything works as I would expect. Link to comment Share on other sites More sharing options...
GeneDavis Posted May 3, 2022 Share Posted May 3, 2022 How did you get over ten miles away from zero? Oh, I didn't read about the someone else. Move the project to 0,0. Set new cameras. Everything will work as expected. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 3, 2022 Author Share Posted May 3, 2022 Thank you both Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 3, 2022 Author Share Posted May 3, 2022 Great, so the CAD Detail From View works, but when I ask the camera to Back Clip it doesn't show the floor or the foundation. Please see attached step by step photos and tell me if I am off base. Also, I moved the drawing to X-0 and Y-0, here is a link to the file as I've got it now. https://www.dropbox.com/s/jjp1fuiw9h7xi1o/Janny and Urs.plan?dl=0 Thanks, Kelly Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 3, 2022 Share Posted May 3, 2022 4 minutes ago, KellySantaRosa said: This is pretty much exactly what I would expect to see with that camera as you have it set up. The only thing missing really are the Cross Section Lines. Turn that layer on. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted May 4, 2022 Author Share Posted May 4, 2022 I would expect to see the foundation and the floor, no? At least that is what I am used to seeing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 4, 2022 Share Posted May 4, 2022 1 hour ago, KellySantaRosa said: I would expect to see the foundation and the floor, no? No. not really. You created a backclipped view meaning everything in the background was cut out of the picture. That just leaves you with whatever is between your camera and the clipping plane. Since your Cross Section Lines layer was turned off you weren't getting any lines being drawn in those areas. You're also not seeing any floor framing because the floor hasn't been framed yet (the framing layers aren't turned on either by the way). And lastly, you want see a fill for your foundation wall unless you either manually create one OR use the Auto Detail tool to create one...and again, the appropriate CAD layer needs to be turned on. Link to comment Share on other sites More sharing options...
