Eglazier8 Posted April 22, 2022 Share Posted April 22, 2022 I'm trying to add bullnose to a shower seat. Since Chief doesn't appear to offer bullnose tile I created a polyline solid, which worked fine until I had to join two pieces where the front and side of the top of the seat come together. Chief won't allow you to cut the ends of the bullnose at 45's and join them. Anyone have advice for how to handle this? Link to comment Share on other sites More sharing options...
Eglazier8 Posted April 22, 2022 Author Share Posted April 22, 2022 I tried clipping the 45's before I rounded the edges and once you have a clipped edge the software won't allow you to round the edge, so it's either one or the other. Link to comment Share on other sites More sharing options...
evergreen Posted April 22, 2022 Share Posted April 22, 2022 It looks like you made two solids. make one solid L-Shaped then bullnose the two edges individually Link to comment Share on other sites More sharing options...
Kbird1 Posted April 22, 2022 Share Posted April 22, 2022 You can likely use a Molding Line for this drawn in Plan View but I haven't tried it yet..... M. Link to comment Share on other sites More sharing options...
MarkMc Posted April 22, 2022 Share Posted April 22, 2022 Top is counter with molding on edge- bottom can be solid, cabinet, another counter... Link to comment Share on other sites More sharing options...
Kbird1 Posted April 22, 2022 Share Posted April 22, 2022 46 minutes ago, Kbird1 said: You can likely use a Molding Line for this drawn in Plan View but I haven't tried it yet..... M. Molding Line does work , though I thought the Grout Lines would work out better with a molding line.... Link to comment Share on other sites More sharing options...
glennw Posted April 23, 2022 Share Posted April 23, 2022 I did this one using a 3D Solid. Filleted the appropriate corners, exploded, applied copies of the tile material to each face and then adjusted each faces material Offset to get the grout lines to line up and create the bullnose tiles. Select All, Make Architectural block or Symbol. 2 Link to comment Share on other sites More sharing options...
rgardner Posted April 23, 2022 Share Posted April 23, 2022 4 hours ago, MarkMc said: Top is counter with molding on edge- bottom can be solid, cabinet, another counter... Haven’t tried this but seems a thick countertop with edge profile would also work? personally I just modeled something similar and needed to show a border with a different pattern/texture. I made it out of 2 solids very quickly. Link to comment Share on other sites More sharing options...
