AndyGump Posted April 30, 2022 Share Posted April 30, 2022 Test plan.planTest plan.planTest plan.planI have a couple of test plans that did not go through but I have that fixed now. When I create a schedule of the electrical stuff some of the electical items will not shut off the labels. Andy. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 30, 2022 Share Posted April 30, 2022 On 4/30/2022 at 8:46 PM, AndyGump said: Test plan.planTest plan.planTest plan.planI have a couple of test plans that did not go through but I have that fixed now. When I create a schedule of the electrical stuff some of the electical items will not shut off the labels. Andy. Expand Schedule tab>Show Schedule Callout Link to comment Share on other sites More sharing options...
AndyGump Posted April 30, 2022 Share Posted April 30, 2022 Well son of a... That works, thank you, sir. I guess I will have to take a deeper dive into the new stuff in X-14. Andy. Link to comment Share on other sites More sharing options...
Dermot Posted April 30, 2022 Share Posted April 30, 2022 Objects can display both normal labels and schedule callouts now. In prior versions, you could only display one or the other. If the object is included in a schedule, the schedule can be set to display just the callout, just the label, or both. The object label will appear when the label has text, the label is not suppressed, and the label layer is turned on. This assumes that it is not in a schedule that is set to just display callouts. The schedule callout will appear when the object is included in a schedule, does not have it's callout suppressed, and the callout layer is turned on. This assumes that the schedule is not set to just display labels. 1 Link to comment Share on other sites More sharing options...
