A_Joseph_PE Posted March 29, 2022 Share Posted March 29, 2022 Good Evening. I am trying to model a rooftop deck over a garage for a relatively simple house. Once I figure out how to get the file under the size limit I will post the file for your viewing pleasure. I zipped this one to see if that would work Would I model the ceiling structure (and the main deck str) as a roof that I pitch at 1/4" - per foot (about 1.9°) and land on a wall that the top plate has been dropped about 8.5" to accommodate the sleepers, decking, slope, and drop of deck below door threshold? Then build a floor on top of that roof somehow to give the appearance of a flat surface? There are other items on the model that I need to address, but this is the one that stumped me (full disclosure, I am not an expert at this software at all, ha!) Kinda stumped on how to model it correctly so it looks right. I guess I could sit there for a long time cutting/drafting a section in AutoCAD, but I would rather find a way to represent it in Chief properly. Thanks Rooftop Balcony.zip Link to comment Share on other sites More sharing options...
Rich_Winsor Posted March 29, 2022 Share Posted March 29, 2022 Your plan file is empty. I had a play with a detached duplex garage with a rooftop deck a while back. I ended up going in a more traditional direction. Link to comment Share on other sites More sharing options...
A_Joseph_PE Posted March 29, 2022 Author Share Posted March 29, 2022 Hmmm... See if this one works... apologies. Rooftop Balcony.zip Link to comment Share on other sites More sharing options...
HumbleChief Posted March 29, 2022 Share Posted March 29, 2022 Is this the house you intended to upload? What, exactly, are you trying to accomplish? Link to comment Share on other sites More sharing options...
A_Joseph_PE Posted March 30, 2022 Author Share Posted March 30, 2022 I am trying to figure out how to properly model in the rooftop balcony. I can think of many ways to brute force method it, but was looking for some guidance on how others do it on here? I am guessing that I would need to model the ceiling str above the garage (where the balcony is) as a roof, then slope it 1/4" per foot. That gives me the proper roof pitch, but also would need to drop it to accommodate for the sleepers, decking, drop from door threshold, etc. IS there a way to represent the sleepers that make the deck floor "flat" in CA? Perhaps I could make another roof plane and flip the pitch but that would not give me the "triangular" sleeper shape? Thanks Link to comment Share on other sites More sharing options...
Mark3D Posted March 31, 2022 Share Posted March 31, 2022 I wonder if you use the room structure to set deck framing leave a airgap where roof components would be add a framing layer floor joist then manually draw roof plane in airgap and framing then convert framing and roof plane to a symbol as that will stop the roof plane messing with the structure Link to comment Share on other sites More sharing options...
