Jambruins Posted March 21, 2022 Share Posted March 21, 2022 What is the best way to draw the house in the attached picture? Create a 2nd floor with 0 ceiling height and then use dormers? Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 21, 2022 Share Posted March 21, 2022 Measure it if it stands and obtain its room ceiling heights and roof pitches or if no house to measure find out if you can obtain a copy of the plans for this home to use to create your own version of it. DJP Link to comment Share on other sites More sharing options...
stephenbc Posted March 21, 2022 Share Posted March 21, 2022 Depending on how the interior of that upper floor is framed (e.g. does it have a flat ceiling in some areas, or is it all vaulted with knee walls), perhaps make a standard floor height and use the roof planes to define the ceiling. Might need to manually modify some roof planes to get the desired pitch. Chief has some videos on how to make dormers and their connected walls (i.e. Manually Drawing Dormers (chiefarchitect.com). Link to comment Share on other sites More sharing options...
Jambruins Posted March 23, 2022 Author Share Posted March 23, 2022 I guess I should have worded my question differently. I don't need to draw that exact house but a new house that has that same look. It will be built with rafters. Should I create a 2nd floor and then use dormers or how do I get an 8' wall on the back side of the house and a 0' wall on the front side? Link to comment Share on other sites More sharing options...
rlackore Posted March 24, 2022 Share Posted March 24, 2022 I believe @stephenbchas the best suggestion: create a second floor and let the roof planes define the ceilings. Dormers can probably be created as usual. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 24, 2022 Share Posted March 24, 2022 20 hours ago, Jambruins said: Should I create a 2nd floor and then use dormers or how do I get an 8' wall on the back side of the house and a 0' wall on the front side? Yes you need a second floor. The shape of the second floor rooms / ceilings will dictate the best way build it, so it's difficult to say the exact approach I would use. Manual roofs might come into play, but I made this in about 30 seconds using the OOB Residential Template with Auto Build roofs: Link to comment Share on other sites More sharing options...
Jambruins Posted March 26, 2022 Author Share Posted March 26, 2022 Did you set the rough ceiling height for the 2nd floor as 8'? What is the oob residential template? Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 26, 2022 Share Posted March 26, 2022 11 minutes ago, Jambruins said: Did you set the rough ceiling height for the 2nd floor as 8'? Yes Actually I didn't "set" it, it was set that way by default 11 minutes ago, Jambruins said: What is the oob residential template? OOB = out of box, refers to the program as it ships, or "out of the box." The Residential Template is a template plan that also ships with the program, so all settings are default factory. Link to comment Share on other sites More sharing options...
