bdillard1 Posted February 26, 2022 Share Posted February 26, 2022 Hello, I'm sure it is simple but no matter what number I change this to the light through the windows seems the same (BRIGHT) Use sun angle drop down is unavailable as well as edit - I imagine that is because I haven't selected a plot or the orientation of the house. The only thing I can do to make it darker outside is toggle sunlight. Link to comment Share on other sites More sharing options...
ericepv Posted February 26, 2022 Share Posted February 26, 2022 Go to 'Rendering Techniques Options' and in the 'Physically Based Rendering' tab (his looks like a PBR) reduce the 'Daytime Backdrop Intensity'. I find that a setting between 200 and 500 works best. Also, make sure your sunlight 'Intensity' (in the 'Adjust Sunlight' DBX) is set for a lower value (usually 5000 - 15,000 works well). 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2022 Share Posted February 26, 2022 On 2/26/2022 at 5:35 PM, bdillard1 said: I imagine that is because I haven't selected a plot or the orientation of the house. Expand It's because you haven't placed a Sun Angle Arrow (Line Dropdown) but it's not necessarily needed....unless doing Sun studies. M. 1 Link to comment Share on other sites More sharing options...
RodCole Posted February 26, 2022 Share Posted February 26, 2022 Just a bit of follow-up no what Eric said about the backdrop intensity. What I find is that at times it can be helpful to drop the backdrop intensity even below 200 in some circumstances. No specific recommendation, just lower it a bit and do a test until the image cleans up. 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted February 26, 2022 Author Share Posted February 26, 2022 On 2/26/2022 at 6:00 PM, ericepv said: Go to 'Rendering Techniques Options' and in the 'Physically Based Rendering' tab (his looks like a PBR) reduce the 'Daytime Backdrop Intensity'. I find that a setting between 200 and 500 works best. Also, make sure your sunlight 'Intensity' (in the 'Adjust Sunlight' DBX) is set for a lower value (usually 5000 - 15,000 works well). Expand Thanks - just tried - no difference on mine. Maybe I missed something. Link to comment Share on other sites More sharing options...
ericepv Posted February 26, 2022 Share Posted February 26, 2022 That's my best guess w/o seeing your other settings, can you post the plan? Link to comment Share on other sites More sharing options...
bdillard1 Posted February 26, 2022 Author Share Posted February 26, 2022 Sure - thanks for taking a look. I'm going to include most things just in case something is weird with the overall plan that is impacting the light. full https://1drv.ms/u/s!AonCBRorVv74rB3mJzh1kpqYmqnX?e=kYHdlM Stripped version https://1drv.ms/u/s!AonCBRorVv74rBvBd4yq1-OYps-H?e=clCf5Q Link to comment Share on other sites More sharing options...
Solution ericepv Posted February 27, 2022 Solution Share Posted February 27, 2022 I made a few adjustments: Camera settings - Turn off Bloom, Set Ambient Occlusion to 25%, Set lighting for 'Default Light Set' Rendering Techniques - In Std tab set Ambient to 0. In PBR, set 'Camera Exposure' to .15, 'Daytime backdrop Intensity' to 25. This should get you started. From here, you can adjust the lighting, sunlight and shadows and also work on your material properties. Hope this helps -Eric 2 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted February 27, 2022 Author Share Posted February 27, 2022 Thanks!! You are right, the daytime backdrop intensity was insane by default. The shades actually can block the sunlight to a degree! I'll get blackout ones for that room but I was using them as a test. Link to comment Share on other sites More sharing options...
RodCole Posted February 27, 2022 Share Posted February 27, 2022 Nice work Eric This will probably help quite a few other folks who are trying to learn Chief's rendering tools. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 27, 2022 Share Posted February 27, 2022 Try these as a starting point Link to comment Share on other sites More sharing options...
RodCole Posted February 27, 2022 Share Posted February 27, 2022 bdillard1 Do you mind following up on this render to show others what you have found that works best for this particular render? The reason I ask is that it is this type of situation that can be most helpful to others who are also trying to learn Chief's rendering tools. Link to comment Share on other sites More sharing options...
ericepv Posted February 28, 2022 Share Posted February 28, 2022 For anyone who is struggling with PBR, take a look at this video from the Knowledge base: https://www.chiefarchitect.com/videos/watch/2426/physically-based-rendering-technique.html These videos provide a lot of great tips on how to set up for the best results. The ones on lighting and materials are especially helpful; https://www.chiefarchitect.com/videos/playlists/103/ray-trace.html 1 Link to comment Share on other sites More sharing options...
