bishoptherooster Posted February 24, 2022 Share Posted February 24, 2022 Does anyone know how to create a custom dining table that I can place chairs under. I know how to resize tables to make a longer table, but the chairs will not go under the table. I want it to look neater. Thanks. new user Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted February 24, 2022 Solution Share Posted February 24, 2022 to place chairs under tables you simply select the chai, then press your keyboard "CTRL" control key, then drag the selected chair under the table. Pressing the Control Key overrides the natural tendency for solid object not to invade the "space" of other objects/symbols in Chief. DJP 2 Link to comment Share on other sites More sharing options...
joey_martin Posted February 24, 2022 Share Posted February 24, 2022 You can also select the chair and open the dbx and tell it to go below the table....think base cabinet.... Link to comment Share on other sites More sharing options...
ericepv Posted February 24, 2022 Share Posted February 24, 2022 59 minutes ago, joey_martin said: You can also select the chair and open the dbx and tell it to go below the table....think base cabinet.... I've never seen that in the object DBX, are you referring to the 'Option' tab in the 'Symbol Specification'? Link to comment Share on other sites More sharing options...
joey_martin Posted February 24, 2022 Share Posted February 24, 2022 1 Link to comment Share on other sites More sharing options...
bishoptherooster Posted February 26, 2022 Author Share Posted February 26, 2022 pressing the control button worked. I am not sure about the other option you mentioned. BTW I have vrs13 Link to comment Share on other sites More sharing options...
