RL-inc Posted January 3, 2015 Share Posted January 3, 2015 I had a problem with my computer and had to create a new user profile on it. I copied everything over from the old profile but some of the bonus libraries and manufacturer libraries didn't come over. ( just some - not all ) when I try import them from the CA website I get the attached error message. any ideas - I am wondering if I should reinstall X5 in this new user profile? Link to comment Share on other sites More sharing options...
lbuttery Posted January 3, 2015 Share Posted January 3, 2015 Rob: no idea.... if nothing comes up over the weekend you may want to contact CA's tech support but if you don't have SSA active - there will be a charge Lew Link to comment Share on other sites More sharing options...
javachip24k Posted January 3, 2015 Share Posted January 3, 2015 Try to run you CA as administrator. Right click the icon and select <Run as administrator> and try to copy again. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2015 Share Posted January 3, 2015 or try making your new User an Administrator as well ,rather than a standard user perhaps , but not sure if possible if you can't access your old profile? Link to comment Share on other sites More sharing options...
RL-inc Posted January 3, 2015 Author Share Posted January 3, 2015 running CA as administrator works - all the libraries are there when i open X5 that way- but will i have t that every time? when i close it down and then reopen through the icon on the task bar i get the same issue. the following error appears for every library folder that is not there when i open X5 in regular mode-[attachmen t=4754:CA SNIP.PNG] is there an issue wit running X% as administrator every time i use it?? Link to comment Share on other sites More sharing options...
RL-inc Posted January 3, 2015 Author Share Posted January 3, 2015 i guess the other question i have is - should i delete X5 from this user profile and re-install. my eventual goal is to remove the previous user profile from the machine all together one i am certain that i have the new profile complete and stable. ( man- i wish i was better at the computer end of this stuff ) Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2015 Share Posted January 3, 2015 You cant delete the only Administrator on a system ,so either make the new user an admin too or Run X5 as admin. as it looks like you are running into privledges issue with the standad user and chief can't update/open certain files as the new user does not have permission , you maybe able to change the permissions to "everyone" but for the non computer techie it is probably easier to reinstall under the new profile (as admin) if you are going to update this week to X6 before the extended sale ends on the 12th ($516), just do that instead, and you'll get X7 in a few months too. http://www.chiefarchitect.com/rebates/ Link to comment Share on other sites More sharing options...
RL-inc Posted January 3, 2015 Author Share Posted January 3, 2015 I think you are on the right track with it- i will talk to my computer gal on Monday and see if i can get rid of the old user completely and make sure that the new user profile has all the proper privileges. Already running X6- just have some plans in X5 that I use. thanks for all the advice. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2015 Share Posted January 3, 2015 X6 will open any X5 plan , unless you share X5 files with others? then saving them in X6 would stop that. if you can get into the old admin profile ? goto control panel > users>open new profile/user and make user an admin too if not already Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2015 Share Posted January 3, 2015 another thought is if you originally installed X5 for "this User Only" you may need to reinstall with the "All Users" option , you may be able to rerun the installer without uninstalling and get a "repair install" option and change that setting , maybe possible to do from Control Panel >Programs>X5 ,click on it and it will give you the option to uninstall or perhaps repair. A Repair install may mean having to reinstall any patches/updates you did on X5 though NOTE: I am not sure if this requires a deactivation and then reactivation or not ,so maybe talk to CA on Monday 1st , you don't want to lose an emergency transfer even though it is on the same machine. Link to comment Share on other sites More sharing options...
