gelbuilding Posted January 17, 2022 Share Posted January 17, 2022 Creating a custom schedule for each bathroom and seem to be missing the first row and the number 1 Watched a lot of videos through cannot understand what im missing. Link to comment Share on other sites More sharing options...
MarkMc Posted January 17, 2022 Share Posted January 17, 2022 9 hours ago, gelbuilding said: missing the first row and the number 1 I'm guessing you are using notes to create the schedule? At least that's the only way I can reproduce what you have. Object number one is there it is just not showing a 2D symbol, if you were to include the number column I bet you would see the number. Which would mean that the object doesn't have a 2D symbol. Right click that row in the schedule and select "open row object". Note tab look at text above line- is it blank? should say %simple_schedule_number% Then the line style tab- is it using a layer that is off? or is the line style a blank? Below are the settings I used to reproduce what you have for the first item.There could be some other way to reproduce it but would need the plan for that. Link to comment Share on other sites More sharing options...
gelbuilding Posted January 18, 2022 Author Share Posted January 18, 2022 Thanks Mark Yes using notes and creating custom categories for the individual room. Works good now. I did another bathroom and when i added the glass shower wall i lost the numbers of the note marker in this room, I changed the room to match the room for the Lables and still dont appear, any suggestions? Both rooms are Ensuite 3. This is from one of the notes in shower area. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 18, 2022 Share Posted January 18, 2022 Hi George, I think the issue now is that you can not specify two specific rooms in the same schedule. I think you need to "Include Objects from Room: " as " All " ( Note that it is Room and not Rooms ). Then hopefully rely on your " Ensuite 3 " Custom Category to isolate the things you need in that schedule. Hope that is it. 1 Link to comment Share on other sites More sharing options...
gelbuilding Posted January 18, 2022 Author Share Posted January 18, 2022 Thanks Mick I changed to (all) and worked perfectly Link to comment Share on other sites More sharing options...
mattyt12 Posted January 18, 2022 Share Posted January 18, 2022 18 hours ago, gelbuilding said: Thanks Mark Yes using notes and creating custom categories for the individual room. Works good now. I did another bathroom and when i added the glass shower wall i lost the numbers of the note marker in this room, I changed the room to match the room for the Lables and still dont appear, any suggestions? Both rooms are Ensuite 3. If you still wanted to keep it room specific you could change the glass wall to have no room definition with this instance Alternatively use fixtures with the attributes assigned which opens up the room location attribute and a little more flexibility Link to comment Share on other sites More sharing options...
