winterdd Posted January 16, 2022 Share Posted January 16, 2022 Hey guys, how do we change this to where it is not set on angles? I am still tweaking my settings on the new PC. Link to comment Share on other sites More sharing options...
Mark3D Posted January 16, 2022 Share Posted January 16, 2022 Double click the select tool Link to comment Share on other sites More sharing options...
Chopsaw Posted January 16, 2022 Share Posted January 16, 2022 56 minutes ago, ChiefUserBigRob said: Hey guys, how do we change this to where it is not set on angles? I am still tweaking my settings on the new PC. Are you changing all your settings or just trying to get the old ones back ? The old ones should be here: C:\Users\User\AppData\Roaming\Chief Architect Inc Link to comment Share on other sites More sharing options...
winterdd Posted January 16, 2022 Author Share Posted January 16, 2022 59 minutes ago, Chopsaw said: Are you changing all your settings or just trying to get the old ones back ? The old ones should be here: C:\Users\User\AppData\Roaming\Chief Architect Inc first time building a roof since downloading onto the new PC. I thought a fresh download of CA wouldn't be defaulted to degrees. Built the roof and changed a roof plane in the dbx manually. should be good now..... Link to comment Share on other sites More sharing options...
Chopsaw Posted January 16, 2022 Share Posted January 16, 2022 10 minutes ago, ChiefUserBigRob said: first time building a roof since downloading onto the new PC. I thought a fresh download of CA wouldn't be defaulted to degrees. Built the roof and changed a roof plane in the dbx manually. should be good now..... That particular roof setting would be part of your plan template. The other reference I gave you is your Preferences in the .ini file. Link to comment Share on other sites More sharing options...
winterdd Posted January 16, 2022 Author Share Posted January 16, 2022 noted chop........this was a plan already started several weeks ago so maybe something just crossed. Link to comment Share on other sites More sharing options...
glennw Posted January 16, 2022 Share Posted January 16, 2022 You can also get to that setting through Build>Roof>Edit All Roof Planes>Pitch In Degrees 1 Link to comment Share on other sites More sharing options...
