ToolBox Posted December 27, 2021 Share Posted December 27, 2021 When I created my plan I had the structure 180 degrees from it's current position. I flipped the plan so the street was at the bottom and all room labels and callouts are upside down. The room labels I just rotated with the handles but the elevation marker doesn't seem to have a way to rotate the text. Any help is appreciated. Link to comment Share on other sites More sharing options...
rgardner Posted December 27, 2021 Share Posted December 27, 2021 Pictures and plan file. Link to comment Share on other sites More sharing options...
ToolBox Posted December 27, 2021 Author Share Posted December 27, 2021 rgardner, It says my plan file is to large to upload. I attached a picture below. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 27, 2021 Share Posted December 27, 2021 It appears you used "Rotate Plan View" so for that to work for the cameras you need to be sure that "Rotate with Plan" is not selected for the "Text Style" that the Cameras Layer is using. 1 Link to comment Share on other sites More sharing options...
ToolBox Posted February 2, 2022 Author Share Posted February 2, 2022 Is there a way to change after the fact? Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 3, 2022 Share Posted February 3, 2022 On 2/2/2022 at 11:27 PM, ToolBox said: Is there a way to change after the fact? Expand Just guessing as I've never done it and not at my computer but I'd try rotating back to original state, with check marked, then uncheck and rotate back. 1 Link to comment Share on other sites More sharing options...
