JFDrafting Posted November 30, 2021 Share Posted November 30, 2021 When I try to load a client's plan I keep getting "objects to far away from origin" but cannot move or delete them. Anybody else have this problem? Link to comment Share on other sites More sharing options...
javatom Posted December 1, 2021 Share Posted December 1, 2021 You might have an object in the plan that you don't know is there. Turn all layers on. Hit F6. This will put everything on the screen. That might help you track it down. Link to comment Share on other sites More sharing options...
JFDrafting Posted December 1, 2021 Author Share Posted December 1, 2021 Thanks. I tried that but could not find anything that shouldn't be there. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted December 1, 2021 Solution Share Posted December 1, 2021 1 hour ago, JFDrafting said: Thanks. I tried that but could not find anything that shouldn't be there. Sometimes Fill Window and then looking around the edge of the screen can find a stray object ..... do you try the KB article? https://www.chiefarchitect.com/support/article/KB-03124/troubleshooting-origin-error-messages.html M. Link to comment Share on other sites More sharing options...
tommy1 Posted December 1, 2021 Share Posted December 1, 2021 If you haven't been able to get it to work yet, then please feel free to call my cell at 832-754-6160. I may have a quick alternative route for you to do that may help. Link to comment Share on other sites More sharing options...
joey_martin Posted December 1, 2021 Share Posted December 1, 2021 Sometimes it's an empty text box. Hold SHIFT and drag outside the plan on each side and see what you find. You won't be able to see it if it's empty, until you select it. 1 Link to comment Share on other sites More sharing options...
JFDrafting Posted December 1, 2021 Author Share Posted December 1, 2021 Thanks Kbird, that was the solution I needed. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 1, 2021 Share Posted December 1, 2021 5 hours ago, joey_martin said: Sometimes it's an empty text box. Hold SHIFT and drag outside the plan on each side and see what you find. You won't be able to see it if it's empty, until you select it. Also a good trick I forgot about... 2 hours ago, JFDrafting said: Thanks Kbird, that was the solution I needed. Glad I could help.... Mick Link to comment Share on other sites More sharing options...
