jcdurand Posted November 30, 2021 Share Posted November 30, 2021 X13 user. I would like to calculate cabinet volume in cubic feet to be able to show a client current versus proposed storage in a kitchen. Using the Materials List, I am unable to create a custom formula because the cabinet depth, height and width is all in one text field. I am hoping there is a way to add a formula in a Custom Object Field for use in a schedule but haven't had luck with this yet, it just produces text (I have tried this through Preferences as well as on an individual cabinet). I also exported the schedule to excel, but the depth, width and height fields have the dimensions as text with " (e.g. 24 ") which does not work in an excel formula. Is there a way to do this? Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 30, 2021 Share Posted November 30, 2021 I could write a custom macro for you that will accumulate the volumes and provide a total. You would just need to place that macro in the cabinet labels (best in the Defaults for Cabinets) and it would create a $Global variable that you could display in a Text Box. If you would like this just send me $25 via PayPal account joe.carrick@dslextreme.com and include your email address so I can send the macro to you. Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 30, 2021 Share Posted November 30, 2021 you could also strip out the " in excel. There are lots of tidbits on the internet for manipulating excel data, adding " as a delimiter might even work using the excel import function Link to comment Share on other sites More sharing options...
jcdurand Posted November 30, 2021 Author Share Posted November 30, 2021 Thanks Joe and Jason for your replies. I thought I was missing an easy solution within Chief but seems like there isn't one. I did end up manipulating the data in Excel to get a volume formula to work. Small project so there weren't that many records (cabinets). Would be nice if Chief had this option. Thanks much. Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 30, 2021 Share Posted November 30, 2021 or just put %depth*width*height% into one of the fields in the object information panel of the cabinet, and then report that on the schedule. result is cu feet 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2021 Share Posted December 1, 2021 34 minutes ago, jasonn1234 said: or just put %depth*width*height% into one of the fields in the object information panel of the cabinet, and then report that on the schedule. result is cu feet The problem there is that I think the main goal was to get a total volume calculation and I don't think you will get it that way with a stock schedule. Link to comment Share on other sites More sharing options...
jcdurand Posted December 1, 2021 Author Share Posted December 1, 2021 I will try that and see, thanks. Link to comment Share on other sites More sharing options...
jcdurand Posted December 1, 2021 Author Share Posted December 1, 2021 2 hours ago, jasonn1234 said: or just put %depth*width*height% into one of the fields in the object information panel of the cabinet, and then report that on the schedule. result is cu feet Thanks the formula formatting worked, however Chopsaw is correct that I am unable to add a total in the standard schedule. But the data can be exported to excel without reformatting which is nice. Thanks for all the comments, appreciate it. Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 1, 2021 Share Posted December 1, 2021 2 hours ago, Chopsaw said: The problem there is that I think the main goal was to get a total volume calculation and I don't think you will get it that way with a stock schedule. I think I put an enhancement request in for that one 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2021 Share Posted December 1, 2021 Just now, jasonn1234 said: I think I put an enhancement request in for that one Excellent. It can be done with ruby but you need to ditch a lot of the other benefits of a Chief Schedule and start from scratch. A few extra clicks would be a great time saver if it could be done automatically. Link to comment Share on other sites More sharing options...
