armfx89 Posted November 29, 2021 Share Posted November 29, 2021 Please see pic. I am trying to do the circled part....wall thickness is around 30" with a closet inside the wall. Only way I can think of is a wall niche...but then I cannot place the door. Any idea how to do this? Thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 29, 2021 Share Posted November 29, 2021 Use thin (normal 2x4) walls front & back of the closet instead of a thick wall. 2 Link to comment Share on other sites More sharing options...
armfx89 Posted November 29, 2021 Author Share Posted November 29, 2021 2 hours ago, Joe_Carrick said: Use thin (normal 2x4) walls front & back of the closet instead of a thick wall. I have tried, it doesn't work Link to comment Share on other sites More sharing options...
rgardner Posted November 29, 2021 Share Posted November 29, 2021 2 hours ago, Joe_Carrick said: Use thin (normal 2x4) walls front & back of the closet instead of a thick wall. Correct way to model it. That is not a thick wall. 1 minute ago, armfx89 said: I have tried, it doesn't work Perhaps you can show with a screen grab picture of what is not working for you? or upload the plan file so someone can try to help you. Link to comment Share on other sites More sharing options...
joey_martin Posted November 30, 2021 Share Posted November 30, 2021 As Ryan said, it's not a 30" thick wall, just some wall framing with a CAD box the same color as the walls filling in the gap. Link to comment Share on other sites More sharing options...
