TriDiWorx Posted November 20, 2021 Share Posted November 20, 2021 Hello! Just a quick question. Can I make this kind of casing as in the picture using window option? Or only manually? The top can be extended with Lintel options the bottom can be extended with apron, but sides? I cannot find an option to extend side casing to the bottom and it seemed a bit weird that there is no option for such a simple thing. Link to comment Share on other sites More sharing options...
joey_martin Posted November 20, 2021 Share Posted November 20, 2021 You will have to do that manually. Link to comment Share on other sites More sharing options...
TriDiWorx Posted November 20, 2021 Author Share Posted November 20, 2021 5 minutes ago, joey_martin said: You will have to do that manually. Ok. Thank you. One more quick question. How to place gutters on square eaves? On plumb eaves it works fine, but on square it is in the air. Also I have had some different eaves where automatic gutter placement is all wrong. Is the any setting for that or I have to also to it somehow manually? Link to comment Share on other sites More sharing options...
Solution MarkMc Posted November 20, 2021 Solution Share Posted November 20, 2021 31 minutes ago, TriDiWorx said: I cannot find an option to extend side casing to the bottom You could fudge it with shutters and custom symbol that has the Y origin offset 1 Link to comment Share on other sites More sharing options...
robdyck Posted November 20, 2021 Share Posted November 20, 2021 2 minutes ago, TriDiWorx said: How to place gutters on square eaves? On plumb eaves it works fine, but on square it is in the air. Also I have had some different eaves where automatic gutter placement is all wrong. Is the any setting for that or I have to also to it somehow manually? Adjust the offset for the gutter. Then you can turn gutters on/off on a per edge basis. Link to comment Share on other sites More sharing options...
TriDiWorx Posted November 20, 2021 Author Share Posted November 20, 2021 1 minute ago, robdyck said: Adjust the offset for the gutter. Then you can turn gutters on/off on a per edge basis. Thanks. I have no idea why I did not see it in months of using Chief Link to comment Share on other sites More sharing options...
robdyck Posted November 20, 2021 Share Posted November 20, 2021 Just now, TriDiWorx said: Thanks. I have no idea why I did not see it in months of using Chief And how weird is this...that's exactly what I'm doing right now! Link to comment Share on other sites More sharing options...
TriDiWorx Posted November 20, 2021 Author Share Posted November 20, 2021 18 minutes ago, MarkMc said: You could fudge it with shutters and custom symbol that has the Y origin offset Thanks. This seems what I need. Could you please elaborate on what is and how to make and use custom symbol? I have not yet used this and not sure on how :). I can manage with shutters, but mine need offset. Link to comment Share on other sites More sharing options...
TriDiWorx Posted November 20, 2021 Author Share Posted November 20, 2021 Just now, TriDiWorx said: Thanks. This seems what I need. Could you please elaborate on what is and how to make and use custom symbol? I have not yet used this and not sure on how :). I can manage with shutters, but mine need offset. I found a material on how to make custom symbol. I will manage. Thanks. Link to comment Share on other sites More sharing options...
