mcrump Posted December 26, 2014 Share Posted December 26, 2014 I have a roof plane sticking out over the garage and I cannot select it to edit it no mater what mode I am in. It's not on a locked layer but I can't pick it, window it or anything. I have never seen this before. Can someone please tell me if it is a bug, or simply operator error. Cheek 1.zip Link to comment Share on other sites More sharing options...
dshall Posted December 26, 2014 Share Posted December 26, 2014 The cause is the auto roof returns on the the gable walls. Manually build this eye brows and you should be okay. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 26, 2014 Share Posted December 26, 2014 Michael, It's the Auto Roof return from the garage wall. If you look at the garage from the front that left side wall has auto roof returns turned on. It looks like you want it turned on for the back corner but as you extend that roof plane to the left it's building a very large return (actually still over the garage wall) that's showing up as that orphaned, wild, roof plane. Can't select because it's auto generated. To fix it I broke that left garage wall in half (see pic below) and spec'd the front half of the wall with no auto roof return. Now you can extend the roof to the left and it won't build the roof return on that side. Link to comment Share on other sites More sharing options...
mcrump Posted December 26, 2014 Author Share Posted December 26, 2014 Thanks a lot guys!! Another lesson learned. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 26, 2014 Share Posted December 26, 2014 What I would like to know is how do you get that railing wall that's up against the garage to butt against the brick instead of ending up a few inches within the brick wall? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 26, 2014 Share Posted December 26, 2014 Use the "Edit wall intersection" tool. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 26, 2014 Share Posted December 26, 2014 Thanks Perry. Never really used it, didn't realize how powerful that tool was. Took a bit to figure it out but it worked great. I'll put that in the data base. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 26, 2014 Share Posted December 26, 2014 Not knowing any better, I played around with the roof planes and noticed if you draw them in separately, Chief eliminates the return causing the problems. Good solution I think, but for me, not being the sharpest tool in the shed, it took a while to figure out it was the return. After that you could probably solve it in a couple different ways. Link to comment Share on other sites More sharing options...
