SH_Canada Posted November 8, 2021 Share Posted November 8, 2021 I've noticed when I open up previous files the rich text box shrunk. instead of I have no idea what event triggered this. My only thought is it was around the time that I removed my second monitor, but really that should have nothing to do with it) anyone seen this before? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 8, 2021 Share Posted November 8, 2021 Was your second monitor a different resolution than the one you are using now ? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 8, 2021 Share Posted November 8, 2021 there is a known issue with Text, when opening plans at different resolutions, been around for quite some time but no fix as yet , the fix is to open the text block , click OK (may not be needed) and close it again..... In some cases it will be faster to go All Layers Off > Turn Text only back on, group select all, open the DBX and close the DBX . * are you sure the Layout is fully Updated? M. Link to comment Share on other sites More sharing options...
SH_Canada Posted November 8, 2021 Author Share Posted November 8, 2021 the resolution looks to be the same on the other monitor, however, extending the desktop acorss both maybe changes it. Anyway as @Kbird1indicates, opening and closing the dbx worked what does 2 hours ago, Kbird1 said: Layout is fully Updated? mean? i zoom in and out and nothing changes Link to comment Share on other sites More sharing options...
robdyck Posted November 8, 2021 Share Posted November 8, 2021 Select all rich text items, open, then press 'OK'. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 8, 2021 Share Posted November 8, 2021 2 hours ago, jasonN said: what does 5 hours ago, Kbird1 said: Layout is fully Updated? mean? Sometimes you will need to manually update the Layout either with the circle Icon on the Toolbar (2) when the layout box is selected or Via the Update Icon up on the Main Toolbar (1) , Text and Dimensions are pretty good at updating immediately though. Link to comment Share on other sites More sharing options...
SH_Canada Posted November 9, 2021 Author Share Posted November 9, 2021 i think that just updates the view? I hit that all the time to update elevations as i have mine as on demand. In this case the shrunk rich text box is on the layout (not part of the plan/elevation). the open up , ok, close, worked, merci Link to comment Share on other sites More sharing options...
Kbird1 Posted November 9, 2021 Share Posted November 9, 2021 16 hours ago, jasonN said: i think that just updates the view? Yes , I was just trying to think of another reason the layout may not look correct if it wasn't the Known Text Issue. I think the Text issue maybe related to the number of Pixels (ppi) rather than resolution of different monitors, but it seems Chief can not fix it as it has been around for 2-3 verions now. M. Link to comment Share on other sites More sharing options...
