Steve_Nyhof Posted November 2, 2021 Share Posted November 2, 2021 Does anyone know how to turn glass into a solid so that in Line Drawing camera mode you cannot see thru it? There are Louvers as a Window Type, but the material seems to be glass and yet you cannot see through the louver panels, only the gaps. Now and then I like to use a window as a panel for under a window, but when I show my model in Line Drawing you can see thru it. Thoughts? Link to comment Share on other sites More sharing options...
rgardner Posted November 2, 2021 Share Posted November 2, 2021 9 minutes ago, stevenyhof said: in Line Drawing camera mode 11 minutes ago, stevenyhof said: Sorry Steve but I am not seeing what you are actually looking for other than using the opaque window glass option in both "line drawing" rendering style (1st example) or if you are referring to a "standard" rendering option w/ line drawing option (2nd example). Are you looking for something else? Link to comment Share on other sites More sharing options...
rgardner Posted November 2, 2021 Share Posted November 2, 2021 20 minutes ago, stevenyhof said: Now and then I like to use a window as a panel for under a window, but when I show my model in Line Drawing you can see thru it. If you are looking on how to do that panel a combination of a thin wall material region combined with a custom cabinet is one of the easier ways to do a panel below the window. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Thank you for jumping on this!! I will try the opaque window glass option. I like the depths the window offers and has a number of options to mess with to match panels to existing remodeled homes. The Region is too flat and I know I can mess with that also, but a window and be a nice panel on a window or under windows on the sides of a door. If all fails, I may just add a solid over the glass. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 I have also been messing with the Properties, but not working - maybe that is more for Physically based Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Yes, Physically Based is what the Properties are for. So then I may request a new Window Type called Panel If there is a Louver, there can be a Solid Panel Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 With the Line Drawing Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 With a polyline solid - works, but more fussing Link to comment Share on other sites More sharing options...
rgardner Posted November 2, 2021 Share Posted November 2, 2021 I strongly recommend you check out using cabinets for those panels. Easily adjusted to what you want and very quickly. The wall material region was only to cut the brick material back to the sheathing layer. Wainscot Panel.calibz 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 Use a separate window with an opaque material. Mull them if you want them to be a single unit. Note that once you get a window set with the desired "glass" material - which can be anything - you can add it to the user library for future use. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 2, 2021 Share Posted November 2, 2021 1 hour ago, stevenyhof said: With the Line Drawing Did you change the Window Glass in the 3 Panel Window to the same material as your Sash? ( Brown?) , the PS should not be needed ....... M. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 1 hour ago, Joe_Carrick said: Use a separate window with an opaque material. Mull them if you want them to be a single unit. Note that once you get a window set with the desired "glass" material - which can be anything - you can add it to the user library for future use. This works in several modes but not Line Drawing Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 14 minutes ago, solver said: What about the inside? What does it need to look like? Good call. But on this job I don't care about the interior. But very true for if you need the wall, then I think I will try using... 1 hour ago, rgardner said: I strongly recommend you check out using cabinets for those panels. Easily adjusted to what you want and very quickly. The wall material region was only to cut the brick material back to the sheathing layer. I will have to give this a try Thank you gentlemen! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 This is what I have... You could remove the trim and add a polyline and paint to match the wall Outside I like that you can control the sash and the frame to get different panel sizes, but a cabinet may do the trick. I like the idea of a window because it plays nice with the windows and doors. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 Steven, Select the window, remove casings, lintel & sill. set the material to something opaque such as "Solid Panel" - then convert to a "Door Symbol" using the little chair on the Edit Toolbar. Once placed in the plan it can be changed to a "Fixed" door and sized vertically to fit below your Window and "Mulled". The "mulling" tool will add the casings, etc to the mulled unit. To edit the panel, select the mulled unit, right click and select next item. That will allow you to modify the materials, etc as desired. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 10 minutes ago, Joe_Carrick said: Steven, Select the window, remove casings, lintel & sill. set the material to something opaque such as "Solid Panel" - then convert to a "Door Symbol" using the little chair on the Edit Toolbar. Once placed in the plan it can be changed to a "Fixed" door and sized vertically to fit below your Window and "Mulled". The "mulling" tool will add the casings, etc to the mulled unit. To edit the panel, select the mulled unit, right click and select next item. That will allow you to modify the materials, etc as desired. I'm trying it, but once it is in my library and I select it, it will not place in plan view or camera view. ??? I removed the casing, lintel and sill. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 I just made it a Doorway and that is working so messing with it now Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Acting a bit funny, does not want to go into the wall in camera view. Going to try without brick Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Nope... Maybe I need to mess with the X, Y and Z sizing? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 I got a Door symbol to fit into the interior wall and it is opaque Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 I did get a door symbol into the exterior so making some progress. I see that it needs a full opening for a large door, so need to size it first and then put the windows above it... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 Go Back and follow my steps exactly. OTOH, here's my Symbol. It should insert into the wall - but not in the same space as the other window. Opaque Window Panel.calibz Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Got it. I think my issue was I needed space to fit the door because it comes in full size and my three windows are 6' wide. Your symbol looks just like mine so I am getting there Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 So that did work just as you proposed, and it is opaque in Line Drawing, but it still has the inside to deal with which would not have the panels below the windows. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 It might be a good option to create a fireplace! Link to comment Share on other sites More sharing options...
