Chief_Matt Posted October 23, 2021 Share Posted October 23, 2021 Is there any way to implement a Reflective Epoxy flooring system for Garages,, Basements, Rec Rooms, ETC? Link to comment Share on other sites More sharing options...
Chopsaw Posted October 23, 2021 Share Posted October 23, 2021 One of the rendering guru's could likely give you a more precise answer but try adding a thin layer of glass to your floor and use a relatively high "Index of Refraction" then ray trace it. Quickie example with bad lighting: Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2021 Share Posted October 23, 2021 Yes you can turn any Image you find online of a Material into a Material for Chief , Chief repeats the pattern however so you want to make at least 4 copies of the Image in Paint for example flipping them Horz. and vertically so the will repeat more seamlessly...of course if you are a Photoshop or PixPlant User this process (seamless textures ) is even easier. I wouldn't say I am a texture Guru , this is just your image above, copied 4 times and rotate in Paint as mentioned above and then turned in a Material applied as a 1/16th floor finish. You can play with the Material's Properties to adjust the Reflection level , depending on the material Class you can adjust the Reflection or the Roughness ..the lower the roughness the higher the shine. https://www.chiefarchitect.com/videos/watch/38/creating-custom-materials-and-colors.html https://www.chiefarchitect.com/videos/watch/83/advanced-materials.html https://www.chiefarchitect.com/videos/watch/10210/material-properties-how-to-import-set-the-pattern-visualize-in-3d.html?playlist=170 Chief Material : Black Swirl Epoxy.calibz Mick Link to comment Share on other sites More sharing options...
Chief_Matt Posted October 23, 2021 Author Share Posted October 23, 2021 Thank you. That helps a little. I think they would need to be bigger so it appears to be more of a random design than a pattern. But it does look very cool. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2021 Share Posted October 23, 2021 7 minutes ago, Chief_Matt said: Thank you. That helps a little. I think they would need to be bigger so it appears to be more of a random design than a pattern. But it does look very cool. I only used 4 copies of the image and only flipped them vert. and horz. , you could easily do many more say 12 or 16 and also rotate etc to make it more Random, but it does depend a lot on the original Image. Link to comment Share on other sites More sharing options...
Chief_Matt Posted October 23, 2021 Author Share Posted October 23, 2021 I meant instead tiling the design, make the tiles larger so it appears more random. I am still learning CA but I think I may be able to come up with something in due time thanks to your help. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2021 Share Posted October 23, 2021 11 minutes ago, Chief_Matt said: I meant instead tiling the design, make the tiles larger so it appears more random. I am still learning CA but I think I may be able to come up with something in due time thanks to your help. You can change the size of the texture I included above to see if it helps...... eg. double it's size , you can also turn off Retain aspect ratio, and rotate it ( on 45 now ) Link to comment Share on other sites More sharing options...
Rpadge Posted October 24, 2021 Share Posted October 24, 2021 By the time you vehicles in the garage, you probably wouldn't notice the pattern Link to comment Share on other sites More sharing options...
Rich_Winsor Posted October 25, 2021 Share Posted October 25, 2021 On 10/23/2021 at 10:13 AM, Kbird1 said: I don't know if this is some sort of evil Rorschach test, but ever since I've seen it I've been having nightmares. 1 Link to comment Share on other sites More sharing options...
