elevations sent to layout
KellySantaRosa
I would like to increase the quality of the elevation drawings sent to layout as shown in the first screenshot. The line weights are also not reflective of the object settings, specifically the stone wall selected in the second screenshot. The line weight is set at 18, but the rendering remains producing a line weight of nearly 1 and when printed sometimes does not show at all. When refreshing the rendering in the layout view, the quality of the reproduction varies depending on the zoom level. When zoomed in the detail is greater but the line weights are reduced. Does anyone know how I can tweak my configuration to produce a uniform rendering? Do I need create a CAD detail here for a more static situation?
Use the rainbow tool while one 2D camera model.
There's a color for the texture (in Vector view) and there will be a pattern color as well.
Check the pattern color.  Make it darker.
If that pattern is light grey, it'll be faded when sent to layout.
