mcrump Posted December 21, 2014 Share Posted December 21, 2014 In setting up defaults I observed that there are three distinct choices for text styles. Are there any advantages of one over the other? The manual really doesn't tell me which one is a preferred method. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 21, 2014 Share Posted December 21, 2014 I use 13 extra text styles for things like all the different labels used in the plans, others include Doors, electrical, Mainly I use them for text size so it's automatic and use layer text size for all. Link to comment Share on other sites More sharing options...
keithhe Posted December 21, 2014 Share Posted December 21, 2014 Perry, you have dimension spelled wrong. Sorry, just had to.... Link to comment Share on other sites More sharing options...
mcrump Posted December 22, 2014 Author Share Posted December 22, 2014 The P Man. I appreciate your explanation, but it doesn't clarify the + and - of the three different choices. Is one better than the other? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 22, 2014 Share Posted December 22, 2014 The P Man. I appreciate your explanation, but it doesn't clarify the + and - of the three different choices. Is one better than the other? I may have created a couple of the same text styles for different types of plans. For me its all automatic so say, I have a 1/2" scale plan which needs smaller text size, so just create another text style just for that occasion. They are all part of the anno-sets so, automatic and I never need to think about that again.. I guess I could have labeled it better but like I say, "What the H***". I always use "Use layer for text style b/c its a lot easier to change it there if you need to. Link to comment Share on other sites More sharing options...
keithhe Posted December 22, 2014 Share Posted December 22, 2014 Perry, just a guess, but OP might not understand that the different sizes are for different layout sizes. For example: Ledger (ANSI B ) Arch D (24x36) You adjust your text size for the paper size you print to. The rest (font, line weights and colors are just preferences). Link to comment Share on other sites More sharing options...
dshall Posted December 22, 2014 Share Posted December 22, 2014 I do not think anybody is addressing what Mr. McCrump is referring to. He is asking whether he should select text via LAYER, CUSTOM or the other option. To answer Mr. McCrump's question, I say use LAYER as the default choice..... and then go from there depending on the situation. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 22, 2014 Share Posted December 22, 2014 I always use "Use layer for text style b/c its a lot easier to change it there if you need to. I did Link to comment Share on other sites More sharing options...
dshall Posted December 22, 2014 Share Posted December 22, 2014 I did Yes you did. Link to comment Share on other sites More sharing options...
keithhe Posted December 22, 2014 Share Posted December 22, 2014 I do not think anybody is addressing what Mr. McCrump is referring to. He is asking whether he should select text via LAYER, CUSTOM or the other option. To answer Mr. McCrump's question, I say use LAYER as the default choice..... and then go from there depending on the situation. Guilty. This means that I may need to start actually reading the OP. Scott, you take all the fun out of this. Link to comment Share on other sites More sharing options...
rlackore Posted December 23, 2014 Share Posted December 23, 2014 I prefer using a single set of annotation layers for each discipline, then use Use Text Style with a text style for each drawing scale. So if I'm producing a 1/4" floor plan, selecting the 1/4" Floor Plan annoset will ensure all the floor plan annotations go on their respective layers (Floor, Text; Floor, Dimensions; Floor, Markers; Floor, Callouts) at the proper scale. Of course, this setup depends on not requiring floor plans at multiple scales within the same drawing set. Link to comment Share on other sites More sharing options...
