Can't get roof rafters to be 16 " oc, reverts back to 24" oc each time
shingabiss
Go to solution Solved by Kbird1,
  • Solution
3 hours ago, shingabiss said:
I built all the framing with the defaults; rafters set to 16 oc.
 I think you got it now ?  but Chopsaw is right...... Existing Roof planes do not rebuild via Defaults ....in newer Versions it will warn you that you need to use Edit All Roof planes instead.
3 hours ago, Chopsaw said:
Use "Edit All Roof Planes"....    You can't change the default for existing roof planes.
