Exporting a Chief site plan with accompanying jpeg into a CAD .dwg file
Ange822
Good morning,
I am helping a college who is having issues exporting a Chief File into a CAD . dwg file.
The issue is, she had imported a .jpeg of a clients survey to draw over to create a site plan.
Now trying to export the file to CAD, it will not export the .jpeg with it (that we sized / rotated into place).
The other option would be just to import the .jpeg into CAD and re-size / rotate to fit, but wasn't sure if their was an easier way.
See the files attached.
thanks in advance for the help!
McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.plan McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.dwg
The plan file doesn't contain the jpg file - be sure to use Backup Entire Plan when you upload files which contain referenced images.
FWIW, I've never run across a program that includes referenced files (images, pdfs, etc.) when it performs a dwg export. Even with AutoCAD you normally have to send along the referenced files as loose attachments.
Not sure if it helps but is Save in Plan Checked in the Imported Image's DBX?     ( Robert mentions it not in the uploaded plan)
I don't think Save in Plan will matter. The Chief export process doesn't include objects like image files, pdfs, etc.
 You may be able to use a third party conversion to do just that but Chief will not do it on it's own.
