nikiley Posted August 30, 2021 Share Posted August 30, 2021 Hello! I am looking for a way to show the callout shape in a door schedule so the label is the same on the plan as the schedule. I know that note schedules will show the callout shape when you select 2D Symbol which is ideally how I'd like it to work, but sadly this does not work for doors. Also, I may need to update my signature, but I am using x13. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 30, 2021 Share Posted August 30, 2021 I don't know a way, but what you want would be a great feature to have. Unless a wizard shows us a way, you should suggest a mod. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 30, 2021 Share Posted August 30, 2021 You could use a note schedule as a door schedule with some fancy macros but then how would you differentiate your note schedules from your object schedules ? I think a little cad touch up once the door schedule is complete would be the better option. Link to comment Share on other sites More sharing options...
robdyck Posted August 31, 2021 Share Posted August 31, 2021 I'd recommend using a legend to identify the different callouts. 1 Link to comment Share on other sites More sharing options...
