Adam_Gibson Posted August 19, 2021 Share Posted August 19, 2021 Can someone explain what this is? It's from the most recent update notes. Link to comment Share on other sites More sharing options...
rgardner Posted August 19, 2021 Share Posted August 19, 2021 This was previously available with exporting the information regarding window glazing/insulation values, etc. to RESCheck Web to run energy code compliance checks. Perhaps they added the ability to export in another format? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 20, 2021 Share Posted August 20, 2021 Actually, we still have Export to Res Check. That's a different tool and I don't believe anything was changed in that regard. The newly listed feature is a simple CSV export option to replace the thermal envelope data that we used to get in the Materials List. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 20, 2021 Author Share Posted August 20, 2021 Thanks guys. Link to comment Share on other sites More sharing options...
krandall Posted October 6, 2021 Share Posted October 6, 2021 Hello All, Does anyone have instructions on how to use the exported thermal envelope data (in CSV format) from Home Designer Pro 2022? Is it possible to import the file into Res Check? I'm guessing probably not since the window U values, wall cavity R values, attic insulation, etc. can't be defined in Home Designer Pro. Can the CSV file be edited for this data? Thank you. Link to comment Share on other sites More sharing options...
RobDesLLC Posted April 29, 2023 Share Posted April 29, 2023 Does anyone know if RHVAC by Elite Software can import thermal envelope data from Chief Architect in CSV format? Link to comment Share on other sites More sharing options...
kylejmarsh Posted October 17, 2023 Share Posted October 17, 2023 Can't believe I missed this so long ago but the Thermal Envelope data is a nice feature. Would be even better if it could be linked to a live schedule instead of an export. Anyway my question is how can we get a 'clean' export of the data? Right now it comes in with the units attached to the numbers in teh spreadsheet and that's a real PITA. Not a biggie but one of those 'I wonder why' things Link to comment Share on other sites More sharing options...
caf200 Posted January 8, 2025 Share Posted January 8, 2025 On 10/17/2023 at 3:29 PM, kylejmarsh said: Can't believe I missed this so long ago but the Thermal Envelope data is a nice feature. Would be even better if it could be linked to a live schedule instead of an export. Anyway my question is how can we get a 'clean' export of the data? Right now it comes in with the units attached to the numbers in teh spreadsheet and that's a real PITA. Not a biggie but one of those 'I wonder why' things It appeared like they were simplifying the CSV layout for some reason. a) The spreadsheet formulas area pretty straightforward for most folks here. b) In todays "ChatGPT"-like LLM world, you can have it read that CSV data and force it to spit it out in whatever format you like as well. Here is my example from Googles Gemini. Output: Floor Area: 1760 sq ft Ceiling Area: 2167 sq ft Wall Area: N (356 sq ft), E (336 sq ft), S (299 sq ft), W (370 sq ft) Window Area: N (71 sq ft), E (186 sq ft), S (16 sq ft), W (51 sq ft) Door Area: N (20 sq ft), E (48 sq ft), S (48 sq ft), W (42 sq ft) Input: Summarize this thermal envelope data. Use this layout as an example using the direction breakdown where applicable: Area: N (# sq ft), E (# sq ft), S (# sq ft), W (# sq ft) CSV formatted data: "Floor","Description","Count" 1,"thermal envelope - floor area","1760 sq ft" 1,"thermal envelope - ceiling area","2167 sq ft" 1,"thermal envelope - wall area - North","356 sq ft" 1,"thermal envelope - wall area - East","336 sq ft" 1,"thermal envelope - wall area - South","299 sq ft" 1,"thermal envelope - wall area - West","370 sq ft" 1,"thermal envelope - window area - North","71 sq ft" 1,"thermal envelope - window area - East","186 sq ft" 1,"thermal envelope - window area - South","16 sq ft" 1,"thermal envelope - window area - West","51 sq ft" 1,"thermal envelope - door area - North","20 sq ft" 1,"thermal envelope - door area - East","48 sq ft" 1,"thermal envelope - door area - South","48 sq ft" 1 Link to comment Share on other sites More sharing options...
