ericepv Posted July 30, 2021 Share Posted July 30, 2021 I have a 3D symbol for a plant (Pyracantha Firethorn) which I need for a current project but it is far too big to bring into Chief. Is there anyone who can convert this to a Chief compatible format and size? https://www.dropbox.com/s/r9i9mb8i1ovcmq6/Pyracantha coccinea.zip?dl=0 - Eric Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2021 Share Posted July 30, 2021 That is simply not a suitable model for Chief. I could convert it and reduce the number of faces/vertices, but no amount of reduction is going to make that a usable model in Chief IMO. Link to comment Share on other sites More sharing options...
ericepv Posted July 30, 2021 Author Share Posted July 30, 2021 That's what I was afraid of, thanks for taking a look Michael. Any thoughts on where I can find a decent, Chief compatible model? I've already tried 3D Warehouse, Turbo Squid, CG Trader (where this model came fro) and many others. There is a nice model in Chief but it doesn't meet the customer's spec. - Eric Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2021 Share Posted July 30, 2021 2 minutes ago, ericepv said: There is a nice model in Chief but it doesn't meet the customer's spec. Can you be more specific as to what you mean by this? Link to comment Share on other sites More sharing options...
ericepv Posted July 30, 2021 Author Share Posted July 30, 2021 17 minutes ago, Alaskan_Son said: Can you be more specific as to what you mean by this? The Chef model ('Pyracantha coccinea 1' in 3D Plants) shows plenty of berries but the leaves look skimpy and grey. There are only two material options, the bark (specified as 'bark') and the branch which is and image of berries and leaves. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2021 Share Posted July 30, 2021 18 minutes ago, ericepv said: The Chef model ('Pyracantha coccinea 1' in 3D Plants) shows plenty of berries but the leaves look skimpy and grey. There are only two material options, the bark (specified as 'bark') and the branch which is and image of berries and leaves. How are you with Photo Shop? You can always edit that image to increase the size of the leaves and/or change their color. Link to comment Share on other sites More sharing options...
ericepv Posted July 30, 2021 Author Share Posted July 30, 2021 29 minutes ago, Alaskan_Son said: How are you with Photo Shop? You can always edit that image to increase the size of the leaves and/or change their color. That's not in my skill set. Link to comment Share on other sites More sharing options...
DzinEye Posted July 30, 2021 Share Posted July 30, 2021 May or may not do the trick for you, but might be worth playing with. I got this by overlapping two plants. One copy is rotated with the color modified with the rainbow tool to use a brighter green. Link to comment Share on other sites More sharing options...
ericepv Posted July 30, 2021 Author Share Posted July 30, 2021 1 minute ago, DzinEye said: May or may not do the trick for you, but might be worth playing with. I got this by overlapping two plants. One copy is rotated with the color modified with the rainbow tool to use a brighter green. I did try that yesterday and showed it to the client but they didn't like it. I've also tried increasing emissivness and placing a green colored bacgroundbehind the plant but so far nothing has been a good solution. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2021 Share Posted July 30, 2021 Here Eric, See if this works for you. I modified so that there are 2 different materials being used. One for the leaves and one for the berries. They're both set to Blend Color with Material so all you should have to do is adjust colors for the leaves and/or the berries separately. Its built out of 2 perfectly overlapping symbols so you'll likely need to make adjustments through the material tab instead of using the Adjust Material tool. Firethorn.calibz Link to comment Share on other sites More sharing options...
ericepv Posted July 30, 2021 Author Share Posted July 30, 2021 Many thanks Michael, I sent to the client. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 30, 2021 Share Posted July 30, 2021 1 hour ago, DzinEye said: May or may not do the trick for you, but might be worth playing with. I got this by overlapping two plants. One copy is rotated with the color modified with the rainbow tool to use a brighter green. Nice OOB thinking Mark.... M. Link to comment Share on other sites More sharing options...
DzinEye Posted July 31, 2021 Share Posted July 31, 2021 6 hours ago, Kbird1 said: Nice OOB thinking Mark.... Thanks Mick! I've done that at times without the color change to make 3D plants look bushier. Link to comment Share on other sites More sharing options...
