RGWhite Posted July 27, 2021 Share Posted July 27, 2021 Take a look at this. Some of the walls do not touch the floor in framing perspective but in the cross section it looks normal. What would be the problem? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 27, 2021 Share Posted July 27, 2021 Did you adjust any of the wall in 3D ? Otherwise you may need to post the plan file because that is not normal. P.S. Signature needs updating when you have a moment. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 28, 2021 Share Posted July 28, 2021 Wall Framing not on Auto? ie you changed something and without Auto Frame On it is still showing the Old Framing.... M. Link to comment Share on other sites More sharing options...
RGWhite Posted July 28, 2021 Author Share Posted July 28, 2021 Here is the plan file. The cross section will show normal but the perspective is off. Never had this problem before. I am using X13. It started as a simple plan (which it is) . After making the rooms the height I want I made the roof plane and the ceiling plane. Then just put on a scissor truss and this is what I get each time. No problem in cross section. Correct Wachs Plan.plan Link to comment Share on other sites More sharing options...
glennw Posted July 28, 2021 Share Posted July 28, 2021 Build>Framing>Build Framing>1st>Subfloor for Floor 2>check Build Floor Framing>or better still check Automatically Build Floor and Ceiling Framing. Link to comment Share on other sites More sharing options...
