truss brackets
winterdd
9 hours ago, ChiefUserBigRob said:
thanks guys!
Hey Rob, here's a simple nut/washer to help you out (just cause you updated your BA profile pic). You can rotate this symbol however you need. What I do, is download a  Simpson dwg file into plan view, convert the outer shape (no holes) to a solid, 1/8" thick, then place this nut/washer centered over each hole. Then convert the solid with nut/washers to a symbol, and then add to your library.
BTW, are you riding a motorbike down your hallway without a helmet or jacket?!
STN22 WASHER.calibz
haha, nope, it was taken in a parked car then background blurred. more up to date. and thanks on the file.......it will be used for sure!
