How to share a plan file
Raldo350
my partner and I lived in different states
I used date and time and also LBX12 in file name
He would use JKX12
thus, we knew who last worked on the plan and what version it was created in
as we also worked on prior versions for clients
With Gmail you can send huge file sizes with no problem
it also helps to have some kind of "zoom" capability
to help discuss design and changes
instead of saying "no, the third window from the door on the left", "do you see it ?"
"ok, look at the ceiling mess above that window
being able to see someone else screen and even recording the session is very handy
with most "zoom" type apps you can even take control of their computer
we used Mikogo: https://www.mikogo.com/
Lew
Assuming that you are both using the same version of the program, the Backup Entire Plan tool is the recommended way of doing this.
Some more information can be found here:
https://www.chiefarchitect.com/support/article/KB-00987/using-the-backup-entire-plan-project-tool-to-send-files-to-another-user.html
https://www.chiefarchitect.com/support/article/KB-00516/sharing-a-plan-file-with-a-home-designer-user.html
  • 3 months later...
2 hours ago, angelaleigh said:
I have used the Backup Entire Plan feature and the person I sent it to says they are unable to edit the .plan file upon opening. What are we doing wrong?
sounds like they have one of the Home Designer Products, for which you need to enable the editing capability  ( will vary depending on version of HD.)
The How To :
Mick.
