pdiaz4 Posted February 8, 2021 Share Posted February 8, 2021 Does anyone know how to draw this corbel connected to the boxed eave? I’m using chief architect premier x12 Link to comment Share on other sites More sharing options...
robdyck Posted February 8, 2021 Share Posted February 8, 2021 8 minutes ago, pdiaz4 said: Does anyone know how to draw this corbel connected to the boxed eave? I’m using chief architect premier x12 Draw a polyline solid in elevation view. Draw it on the wall, then move it to the left the correct amount. Set it's thickness as desired. Remember, it will be on the wall, so if you set it to be 4" thick, you'll need to move it 4" back to be flush with the wall cladding. Once it's flush, the material will blend perfectly. Don't forget to set it's layer to whatever works for you. For example, I have an Exterior Trim layer. 1 Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 8, 2021 Author Share Posted February 8, 2021 Thank you, Any time I draw the poly line and make it into a solid, it creates only a mold around it and doesn't give me thickness options. Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 8, 2021 Author Share Posted February 8, 2021 16 minutes ago, solver said: Use the Polyline Solid tool. Thank you, Now it’s doing this. If I move it to the right, it over laps lines and doesn’t look blended Link to comment Share on other sites More sharing options...
robdyck Posted February 8, 2021 Share Posted February 8, 2021 34 minutes ago, pdiaz4 said: Thank you, Now it’s doing this. If I move it to the right, it over laps lines and doesn’t look blended In Plan View, select the polyline solid, move it away from the wall, then back towards the wall. it should 'bump' up against the siding and stop. OR use the 'point-to-point' move tool to accurately place the solid to the corner of the wall. Then, select the wall, open the dialog box, then close it. The material will then blend. YOU MUST BE ACCURATE!! Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 8, 2021 Author Share Posted February 8, 2021 40 minutes ago, robdyck said: In Plan View, select the polyline solid, move it away from the wall, then back towards the wall. it should 'bump' up against the siding and stop. OR use the 'point-to-point' move tool to accurately place the solid to the corner of the wall. Then, select the wall, open the dialog box, then close it. The material will then blend. YOU MUST BE ACCURATE!! I’m sorry I’m just bombing this. I did the point to point and brought it out so it could bump against the siding. Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 8, 2021 Author Share Posted February 8, 2021 I apologize, a little new at this, as you can tell.. But at this point I'm just trying to figure out if it's even possible for it to blend like the very first picture. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 9 hours ago, solver said: I've never been able to get rid of the vertical line between the wall and solid in anything other than standard view. I have no problem getting rid of the lines as long is everything is actually lined up. It's probably worth noting though that you do have to hit F12 or click Rebuild 3D in some situations to get a pre-existing camera to remove that line. 1 Link to comment Share on other sites More sharing options...
glennw Posted February 9, 2021 Share Posted February 9, 2021 Is the corbel thin like a wall (like the pic below), or does it run all the way along the wall like a frieze? I used a wall to do this very quick one. 1 Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 9, 2021 Author Share Posted February 9, 2021 2 hours ago, glennw said: Is the corbel thin like a wall (like the pic below), or does it run all the way along the wall like a frieze? I used a wall to do this very quick one. It is thin like the wall Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 9, 2021 Author Share Posted February 9, 2021 6 hours ago, Alaskan_Son said: I have no problem getting rid of the lines as long is everything is actually lined up. It's probably worth noting though that you do have to hit F12 or click Rebuild 3D in some situations to get a pre-existing camera to remove that line. Thank you! Did you use poly line and make it a solid as well? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 2 hours ago, pdiaz4 said: Thank you! Did you use poly line and make it a solid as well? No. I just used a Polyline Solid as Robert suggested in the very first response. Link to comment Share on other sites More sharing options...
glennw Posted February 9, 2021 Share Posted February 9, 2021 6 hours ago, pdiaz4 said: It is thin like the wall In that case you can use a wall and shape it in an elevation view in the same way as shaping the polysolid. Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 9, 2021 Author Share Posted February 9, 2021 8 minutes ago, glennw said: In that case you can use a wall and shape it in an elevation view in the same way as shaping the polysolid. How do I shape it in the elevation view? I try creating breaks and it won't allow me to break and manipulate it Link to comment Share on other sites More sharing options...
glennw Posted February 9, 2021 Share Posted February 9, 2021 2 hours ago, pdiaz4 said: How do I shape it in the elevation view? I try creating breaks and it won't allow me to break and manipulate it You don't shape the side of the wall, you shape the bottom of the wall. Create a new short wall that extends out to the fascia, drag the bottom of the wall up and start shaping it. The bottom of the wall becomes the underside of your curved corbel. The big drawback is you can't shape it into a proper curve. What I did was draw a circle to the shape, placed break points in the wall and then snap the break points to the circle. Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2021 Share Posted February 11, 2021 On 2/8/2021 at 2:21 PM, pdiaz4 said: I’m sorry I’m just bombing this. I did the point to point and brought it out so it could bump against the siding. The secret to the blend...Then, select the wall, open the dialog box, then close it. The material will then blend. Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2021 Share Posted February 11, 2021 @pdiaz4 Follow the steps in the video. Couldn't be easier. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 11, 2021 Share Posted February 11, 2021 28 minutes ago, robdyck said: The secret to the blend...Then, select the wall, open the dialog box, then close it. The material will then blend. Hitting F12 is a lot faster. 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2021 Share Posted February 11, 2021 6 hours ago, Alaskan_Son said: Hitting F12 is a lot faster. For Sure! But it doesn't work for everything that needs to be rebuilt. I'm just stretching an attic wall and F12 won't get the frieze to build on the new portion. Open & close on the roof plane does! So I've certainly got a habit of just doing a double-click then press Enter right away. Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 16, 2021 Author Share Posted February 16, 2021 On 2/10/2021 at 9:10 PM, robdyck said: @pdiaz4 Follow the steps in the video. Couldn't be easier. So I did it exactly how the video was, I tried f12, I tried rebuild walls and it doesn't work. I drew another plan to see if it was me not doing it correctly and it worked, I'm assuming it's because of that second wall kinda creeping out but the walls are the same sizes. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 16, 2021 Share Posted February 16, 2021 26 minutes ago, pdiaz4 said: So I did it exactly how the video was, I tried f12, I tried rebuild walls and it doesn't work. I drew another plan to see if it was me not doing it correctly and it worked, I'm assuming it's because of that second wall kinda creeping out but the walls are the same sizes. Looks to me like your objects aren't properly aligned. Might help to make sure your various snaps are turned on, especially Bumping/Pushing... Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 16, 2021 Author Share Posted February 16, 2021 All of them are turned on Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 16, 2021 Author Share Posted February 16, 2021 Here's the plan. Sandcrest SPEC.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 16, 2021 Share Posted February 16, 2021 58 minutes ago, pdiaz4 said: Here's the plan. Sandcrest SPEC.plan You snapped to your finish layer on the left side (the correct thing) and to your framing layer on the right side (the incorrect thing). Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 16, 2021 Author Share Posted February 16, 2021 So the left corbel is correct but still isn't blending in. Link to comment Share on other sites More sharing options...
