Chrisdutch89 0 Posted January 12 i have Chief X12. I'm trying to design a two slope roof and am following the instructions on the help page. I set the the lower roof slope at 3 on 12 and have the walls drawn. When I attempt to drawn the "Marquis Window" using the build command I can't drawn the window I can only draw another wall. So I wind up not having a two slope roof even after I've set the upper roof slope at 6 on 12. Can anyone help me? Christopher O. Dougherty, RA,AIA,LLC Chief 12X PO Box 244 Pompton Lakes,NJ 07442 Share this post Link to post Share on other sites
Alaskan_Son 2536 Posted January 12 I’m really not sure what you’re talking about about but it sounds like you must be trying to marquee select walls. If so, you have to hold down the Shift key while drawing your “window”. Share this post Link to post Share on other sites
DavidJPotter 324 Posted January 13 What do you mean when you say "Marquis Window" ? What does the window have to do with the roof planes in your opinion? I agree with Michael, and Eric above in terms of your post and what you may or may not be asking. DJP Share this post Link to post Share on other sites
Chrisdutch89 0 Posted January 13 David, Good evening. Thanks for getting back to me. The term I should have used was a rectangular selection marquee around the area I was working on. I did get an answer that helped. The article for double slope roof doesn't note that I needed to click the shift button and hold it while I was dragging the window across the drawing. When I did that I was able to highlight the drawing and design the roof. I'm still working on it now. Chris Share this post Link to post Share on other sites
SNestor 511 Posted January 13 2 hours ago, Chrisdutch89 said: David, Good evening. Thanks for getting back to me. The term I should have used was a rectangular selection marquee around the area I was working on. I did get an answer that helped. The article for double slope roof doesn't note that I needed to click the shift button and hold it while I was dragging the window across the drawing. When I did that I was able to highlight the drawing and design the roof. I'm still working on it now. Chris Just FYI...you can use Auto Rebuild Roofs and use the "roof tab" in the Wall Spec Dialogue Box to set (2) unique roof pitches. I created the attached example model using auto rebuild roofs...didn't manually draw a single roof plane. It's a powerful tool... See pic attached: 1 Share this post Link to post Share on other sites
