Text from Excel
Apollosg
Hoping someone can help figure out how to change this.  I did this a while ago, by pasting excel cells into a regular text box.  I am not sure how I manipulated the grid to allow for more than one line of text in the header box, but can't seem to recreate it in another similar table.  Also, if I try to shrink the last column "Length" it reverts to one line.  What are the controlling factors for this?
I have attached a Layout and the table pic in question.
Solar B.layoutSolar B.layout
Thanks,
Gary
Solar B.layout
You will need to compress the columns to create the multi line column headers but there is a problem which I would consider a bug in that once the width of the first or last column's is established it can not be reduced without collapsing the other columns to a single line which just makes a mess of your schedule, so if for instance if you wanted to reduce your text size you are in a heap of trouble.
Hoping it will be fixed in X13 but you know how that works......   An undisclosed number of people need to send in the same report. :wacko:
This only works if you have Auto Width checked.
The factors are many and as Chopsaw alluded to above, seem to be somewhat controlled by the initially pasted text.  That being said, the main controlling factors are the Tab Stops and the Margins, and you can gain quite a bit of control by individually adjusting those. Also...
Not quite correct.
First...The first column can indeed be resized.  Don't do it using the left side of the column though.  Do it using the right side.
Second...Just a quick power tip, but you can reset the seemingly uncontrollable width of the column on the far right to its minimum width by unchecking Auto Height and Auto Width, changing both those settings to zero and then immediately rechecking both.
27 minutes ago, Alaskan_Son said:
Not quite correct.
Michael, the depths to which you have
explored this software are almost beyond
belief and I am duly impressed.
Please don't take this in the wrong way
but the above description triggered the
following vision in my mind.  B)
You put your right foot in
You take your right foot out
And you shake it all about
You do the hokey pokey
And you turn yourself around
That's what it's all about
You put your left foot in
You take your left foot out
You put your right hand in
You take your right hand out
You put your left hand in
You take your left hand out
You put your whole self in
You take your whole self out
I can’t believe you just typed that whole song!!  :lol:
