Kbird1
Making Chief Use Your Nvidia Graphics Card , if needed.
How to change NVIDIA Optimus graphics settings
Dec. 2020 :  Window's 10 also now has a some built in control of what graphics processor is used but this is my preferred method....
It maybe worth updating your Intel Drivers ( download the Intel Driver and Support Assistant )  as well but in general
this is an issue of the Nvidia (NV) Discrete Graphics Card not being used by Chief in your Laptop , and some Desktops.
Many laptops ( and some Desktops ) come with both an Intel UHD Graphics Card and a Discrete Videocard Card
eg a Nvidia Geforce GTX or RTX  (or AMD Radeon), which is the Card, Chief should be using especially in 3D Windows.
The Issue lies in that Chief is not "seen" as a 3D Game by Nvidia's Driver,(NV), so the switch may not always happen automatically,
so we need to ADD Chief to the Nvidia Control Panel 3D Manage Page , and set the Nvidia card to be always used when Chief is Open
ie: make it the  "Preferred Graphics Processor" ,            this will likely need resetting EACH time the Driver is updated.....
                                                  Desktop NV CP  1        Desktop NV CP  2
                                          ( Chief already added to list )        How to add Chief to the "List"
19703040_L.DesktopNvidia1.thumb.PNG.345d7cb97fcfe83f362278ea14ddec11.PNG         image.thumb.png.d33f330532bd6eaf9a096ddce4fbd754.png
General Laptop "everything uses" NV Card Setting                                                              Laptop Chief NV CP Settings
( I recommend this  only if plugged in to AC )
1357174099_LaptopNvidia3Dmanage1.thumb.PNG.6c575dd40b7e07f57dd065007dc262ab.PNG         1736923144_LaptopNvidia3Dmanage2.thumb.PNG.a08863453c6053733f2fed4d0ca49483.PNG
                        This mode will use a lot of your battery quickly                           Once set don't forget to set the Options ie No# 7 and 8 above in Desktop pic 2 too.
  • Upvote 2
Hey there,
Thanks for this. I was fiddling with this today on a new PC.
Any tips on if this can also be switched for Ray Tracing? I made the change and it seems to be running better but Ray Trace uses 100% CPU and barely any of the GPU.
Thanks
9 minutes ago, RileyCrosby said:
Hey there,
Thanks
Thanks, that is how the Current Raytracing works -- it is all CPU based --  there is a new PBR-RT view coming in X13 which will use the Nvidia RTX Cards in the 2000 or 3000 Series though, in Windows.
However the old views will remain for those with older hardware to use also.
Check out the What's Coming 3D rendering Video if you haven't already.
Thanks for this.  I wasn't aware of these settings, and I've noticed an improvement in performance now that they are set.
Thanks so much Mick!  We all can use a performance boost on our computers regardless of specs!  Thanks so much for taking the time to show us this, I really appreciate it!
IMO this post should be pinned here.  Perhaps this should be detailed in an official CA getting started guide.
You glossed right over this but I'm not sure why.  It's super easy, I believe its the same on both a desktop and a laptop, and I don't think it needs to be done every time you update drivers either.  Can you elaborate or why you prefer using the Nvidea Control Panel?
This is the Windows method by the way...
Thanks for the Thanks :)  it's good to know moving the Old Post here to Tips is letting others Find it easier , and make use of it.
As Michael has pointed out in newer version of Windows 10, Microsoft is now able to also take Control via the Settings App, YMMV though.
Mick.
This post was 1st made back in 2017 or 2018 but was buried in a Thread , and seeing the same question asked again in Dec., I decided to put it over here in Tips too, to make it easier to find.
In Win 10 190x the Settings App did not work for me and I had to use method above, there are however more options in Win 10 2004/202H though I see now that I have it.
Mick.
So glad you decided to repost the old post because many great posts get buried over time and they often times have such great gems of information!  Glad to see it when I did!
    29150
    EliasGrey
    EliasGrey
  • Similar Content
    • By Kbird1
      Hi, just wondering if anyone else is seeing the disappearing Icon in the Drawing Area with the latest Nvidia Driver in X11, it has happen twice today already,so I may need to go back to the 436 Series Driver which I had no issues with.
      This was also an Issue with X11 back with the 388-396 Series Drivers when 382.05 was the best driver to go back too but I have not seen it since 400 Series Driver came out.
    • By neringa
      Hi! All my 3d vector views are blurry: full camera and then racetrace also. I have tried changing all kinds of settings..to no avail.
      I am using Chief X9. The truth of the matter is that ever since I switched over to X9, my vector views are not crisp like they were with my older version of Chief
      and no matter what I do, my raytraces are flat.I was wondering if it could be a graphics card problem? I have windows 10, 64 bit, plenty of memory...
      my graphics card is NVDIA Quatro 600/PCIe/SSE2. When I purchased X9, I was told and I also checked it out, that the graphics card was good.
      What does anybody think? Could it be something else? Attached, please see an image which shows the flatness of things in progress. Any suggestion is greatly appreciated!
    • By Westlanedesigns
      I recently had a new desktop built. My video card is a Nvidia GTX 1070. It is an 8GB card. when I look at my message log it says I only have 4GB of ram.
                  OpenGL Vendor: NVIDIA Corporation
                  OpenGL Renderer: GeForce GTX 1070/PCIe/SSE2
                  OpenGL Version: 3.3.0 NVIDIA 384.76
                  OpenGL VRam: 4095
                  OpenGL GPU Count: 1
                  OpenGL GPU VRam: 4095
                  OpenGL GPU Driver Name: nvoglv64
                  OpenGL GPU Driver Date: 6-27-2017
                  OpenGL GPU Driver Version: 22.21.13.8476
                  OpenGL GPU Model: NVIDIA GeForce GTX 1070
                  OpenGL GPU Device Path: pci\ven_10de&dev_1b81
      Here is my system.
      Windows 10 Pro
      Intel Core i7-6900K
      Nvidia GTX 1070
      Crucial MX300 275GB SSD
      Crucial 4X4GB DDR4 2400 RAM
      Anyone have a similar issue? I have Chief X8 and X9 on this system. The message log in both programs say the same thing. If anyone is running Windows 10 Pro with an 8GB card can they have a look at their message log and tell me if you are getting a similar message? This could just be a logging issue.
    • By agrogers
      Hi
      I am sure I must be doing something wrong because this seems like such an important feature that it must be somewhere.
      I just want to print an elevation view (see http://screencast.com/t/d10xdX2yKJ) at the same quality that I print a plan view. I can 'Print an Image' but that is just a screen export and so the resolution is no higher than the screen resolution. When that is printed to A4 or worse A3, the text is horrible with smaller text unreadable.
      How do I:
      print a high res elevation view or export a good quality elevation Thanks
      Andrew
